查看: 304|回复: 11
Flatbed
 楼主| 发表于 2021-5-5 23:16:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Thinking about buying a flatbed. Good idea or bad??","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-5-6 02:03:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only way I'd consider flatbed is with a Conestoga like Pete.","replyToPid":0}
发表于 2021-5-5 23:25:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"go stepdeck better","replyToPid":0}
发表于 2021-5-6 09:17:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have pulled a '53 stepdeck for years and have made a very good living with it. For what I do, it gives me the option of doing OD, which I do not do a lot, but I do some. tarping is a pain in the behind and takes time. Conestogas are much easier, quicker. In the end it just boils down to your situation.","replyToPid":0}
发表于 2021-5-6 02:19:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used to pull heavy and OD loads but didnt like the idea of not having that option with a conestoga.  But now I'd reconsider with all the limitations you have on OD loads: no running after dark, times you cant run thru a city: rules about weather. I know there are guys out there that make tall coin and dont mess with permit loads.","replyToPid":0}
禁止发言
发表于 2021-5-6 05:19:13 来自手机 | 显示全部楼层
发表于 2021-5-6 05:05:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rates are strong across the board on all  freight types for a while but you have to have a strategy for staying profitable in the slow times as well. If you think you can then it’s a solid idea. Building materials aren’t usually very profitable so I’d stay away from logs maybe loll","replyToPid":0}
 楼主| 发表于 2021-5-6 07:04:23 来自手机 | 显示全部楼层
147103 发表于 2021-05-05 21:19:13 I have been pulling RGN 30 plus years. I enjoy the challenge.  Right now my rates are very strong!. But the kind of job I do isn't for everyone. Lots of headaches. I have a friend pulling a low profile 53ft step. Who is doing very well with it.
","text":"I have moved alot of large equipment through the years and I do enjoy it, but have always done it local","replyToPid":424586}
 楼主| 发表于 2021-5-6 07:01:36 来自手机 | 显示全部楼层
977252 发表于 2021-05-05 21:05:26 Rates are strong across the board on all  freight types for a while but you have to have a strategy for staying profitable in the slow times as well. If you think you can then it’s a solid idea. Building materials aren’t usually very profitable so I’d stay away from logs maybe loll
","text":"lol logs is what I've hauled my hole life, I'm ready to try something new","replyToPid":424583}
 楼主| 发表于 2021-5-6 00:14:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"More versatile?","replyToPid":424553}
 楼主| 发表于 2021-5-6 00:16:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"My only problem is I has a heavy spec truck, so I have to watch my weight","replyToPid":0}
 楼主| 发表于 2021-5-6 01:32:22 来自手机 | 显示全部楼层
766797 发表于 2021-05-05 17:02:35 do RGN  when heavy they pay for it💲
","text":"I don't mind hauling heavy as long as the $ is good!","replyToPid":424562}
GMT+8, 2026-4-20 06:31 , Processed in 0.107502 second(s), 24 queries .
