查看: 609|回复: 17
when is the 72 hour dot inspection take place this year
 楼主| 发表于 2021-5-3 22:30:40 来自手机 | 显示全部楼层 |阅读模式
禁止发言
发表于 2021-5-4 00:04:04 来自手机 | 显示全部楼层
回复 支持 3 反对 2
发表于 2021-5-4 05:20:23 来自手机 | 显示全部楼层
279311 发表于 2021-05-03 21:00:50 Do they actually inspect in the middle of the night or is it all bs? I’ve been driving for a few years and I cannot seem to recall a pattern. Then again, I use a bypass device.
","text":"I do, too. They're called a GPS and an atlas. 😂","replyToPid":424429}
发表于 2021-5-3 23:14:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank the Gods for the 72 hour ATO.  Amirite?","replyToPid":0}
禁止发言
发表于 2021-5-3 22:52:43 来自手机 | 显示全部楼层
禁止发言
发表于 2021-5-4 23:54:50 来自手机 | 显示全部楼层
发表于 2021-5-4 05:39:28 来自手机 | 显示全部楼层
279311 发表于 2021-05-03 21:29:06 I know what you mean. I personally haven’t had any serious issues with weigh stations using a bypass device. I get stopped maybe 10% of the time, and it’s mostly just to check my weight.\n\nIf I get inspected, it’s almost always a level-3 inspection, which is pretty much checking your logs. I run legal.
","text":"I hear ya. I personally haven't been inspected during a blitz since 2006, knock on plastic, but I was hit with a random roadside level 1 a couple months ago and passed.","replyToPid":424434}
发表于 2021-5-4 05:29:06 来自手机 | 显示全部楼层
1053199 发表于 2021-05-03 21:20:23 I do, too. They're called a GPS and an atlas. 😂
","text":"I know what you mean. I personally haven’t had any serious issues with weigh stations using a bypass device. I get stopped maybe 10% of the time, and it’s mostly just to check my weight.\n\nIf I get inspected, it’s almost always a level-3 inspection, which is pretty much checking your logs. I run legal. ","replyToPid":424432}
发表于 2021-5-4 03:29:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tomorrow but Texas is pulling everyone over today. Seen more dot pulling over rigs this morning than I have all last month in dfw area. But if your legal dont worry about it. ","replyToPid":0}
发表于 2021-5-4 05:00:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do they actually inspect in the middle of the night or is it all bs? I’ve been driving for a few years and I cannot seem to recall a pattern. Then again, I use a bypass device. ","replyToPid":0}
发表于 2021-5-4 03:58:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bend over, ladies & gentlemen....they bout 2 get all up in those crevices!!!","replyToPid":0}
 楼主| 发表于 2021-5-3 23:19:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"what time does it start at midnight or till morning tomorrow","replyToPid":0}
GMT+8, 2026-4-17 21:23 , Processed in 0.108662 second(s), 24 queries .
