查看: 76|回复: 1
Reefer Weights
 楼主| 发表于 2019-1-28 17:32:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm doing some research on reefer weights. If you know the empty weight of your reefer, as well as the reefer model (e.g. Great Dane Super Seal, Great Dane Super LT, Wabash Arctic-Lite) please post it along with the length, width, height and year model. Thank you.","pics":"[]","canComment":true}
发表于 2019-2-28 11:59:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Great Dane is most always the heaviest trailer but also the most durable and longest lasting. I have a Pete 389 280” wheelbase truck and a 53’ Great Dane Everest SS. I weigh a little over 36k full of fuel. Basically I can scale up to 44,000 lbs. no problem. Rarely do I haul anything heavier and if I do you just have to run about 1/2 full of fuel to scale it.","replyToPid":0}
GMT+8, 2026-2-4 12:17 , Processed in 0.057748 second(s), 23 queries .
