查看: 205|回复: 4
VNL 760 Air Consumption question
 楼主| 发表于 2021-4-30 22:55:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I got a brand new truck VNL 760. When I'm on the road every 5-10 minutes or so my air compressor kicks back on because the service air pressure gauge goes to 100psi. I've never had a truck like this before so I'm not sure if I'm having air loss or if it's just a normal deal with the truck. Had the lines and airbag suspension checked, no huge leaks according to a mechanic but he kind of rushed me through the shop because they were busy so I'm not 100% sure. Sorry if this is a noob question. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2021-5-1 06:41:57 来自手机
{"replyTo":"","text":"Oh no I did my airbrake test. I'm saying that when I'm driving the air pressure goes out really fast. Dumbass, learn how to read.","replyToPid":0}
支持 5 反对 0
发表于 2021-4-30 23:29:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"you have a CDL and you don't know how to do a basic air leak test? you POS.\n\nhttps://youtu.be/PQ_dhknNAPM"}
发表于 2021-5-1 08:25:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I know our steering wheel adjustment which is air powered leaks very slowly but you can’t hear it. Who tf knows honestly. Be safe brother ","replyToPid":0}
发表于 2023-12-3 10:26:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the air dryers but if your trailer has a bad chamber youll hear air in your dash","replyToPid":0}
GMT+8, 2026-3-20 22:15 , Processed in 0.106224 second(s), 24 queries .
