查看: 379|回复: 10
Inquiring about a D.O.T. numbers for a truck?
 楼主| 发表于 2021-4-28 07:32:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"How much does it cost to get a D.O.T. and MC numbers?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-4-28 22:45:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Call OOIDA and they will have everything you need ","replyToPid":0}
发表于 2021-5-5 02:57:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Several companies will get you all the permits you need for about $1,000. I highly recommend to go with OOIDA. They’re one of the best resources for new owner operators. All the permits are really not very expensive to get. Perhaps the only costly permit is your truck registration. Here in TX it’s almost $2,000 if I remember correctly. The cost can vary from state to state.","replyToPid":0}
 楼主| 发表于 2021-5-26 03:56:05 来自手机 | 显示全部楼层
279311 发表于 2021-05-04 18:57:36 Several companies will get you all the permits you need for about $1,000. I highly recommend to go with OOIDA. They’re one of the best resources for new owner operators. All the permits are really not very expensive to get. Perhaps the only costly permit is your truck registration. Here in TX it’s almost $2,000 if I remember correctly. The cost can vary from state to state.
","text":"I'm an OOIDA member. 😊","replyToPid":424509}
发表于 2021-4-28 18:30:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"When i got my mc it was $300 per and usdot was free . But you also need a federal tax id number to start . ","replyToPid":0}
发表于 2021-5-23 23:23:33 来自手机 | 显示全部楼层
957369 发表于 2021-04-28 10:30:11 When i got my mc it was $300 per and usdot was free . But you also need a federal tax id number to start .
","text":"hi dear","replyToPid":423911}
发表于 2021-5-23 23:24:57 来自手机 | 显示全部楼层
617944 发表于 2021-04-28 14:45:28 Call OOIDA and they will have everything you need
","text":"hi there","replyToPid":423930}
发表于 2021-5-23 23:26:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"wow","replyToPid":0}
发表于 2021-5-23 23:34:31 来自手机 | 显示全部楼层
 楼主| 发表于 2021-5-26 03:55:33 来自手机 | 显示全部楼层
","text":"I am an OOIDA member, so I'll give them a call.","replyToPid":423930}
GMT+8, 2026-4-17 19:54 , Processed in 0.103274 second(s), 24 queries .
