查看: 165|回复: 4
Jakes
 楼主| 发表于 2021-4-23 12:12:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"I've got a CAT..C15 twin turbo with really CRAPPIE JAKES..!! can someone tell me... are there any better jakes the the STOCK O.M E. jake for Cat ??","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-4-25 21:32:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a good mechanic to do a top set and set up the jakes, I have a C15 twin and it works really well ","replyToPid":0}
 楼主| 发表于 2021-4-26 21:42:44 来自手机 | 显示全部楼层
659218 发表于 2021-04-25 13:32:11 Get a good mechanic to do a top set and set up the jakes, I have a C15 twin and it works really well
","text":"Thanks... I' ll try that. I still have to get a new set of jakes thou...\nso about how much did that cost. you... if you dont mind me asking","replyToPid":423565}
发表于 2021-4-27 06:43:14 来自手机 | 显示全部楼层
208374 发表于 2021-04-26 13:42:44 Thanks... I' ll try that. I still have to get a new set of jakes thou...\nso about how much did that cost. you... if you dont mind me asking
","text":"yes have overhead run that will take care of it","replyToPid":423707}
 楼主| 发表于 2021-4-30 02:24:35 来自手机 | 显示全部楼层
1092870 发表于 2021-04-26 22:43:14 yes have overhead run that will take care of it
","text":"I have a new head put on and motor rebuilt... so the rack was done and than once again...\nsame... Crappie jakes","replyToPid":423733}
GMT+8, 2026-3-21 02:08 , Processed in 0.071056 second(s), 24 queries .
