查看: 161|回复: 3
Do you bottles unscrew in your truck?
 楼主| 发表于 2021-4-21 08:32:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is it normal to have loose bottle caps in your truck because now my phone screws are loose too. All my soaps come loose and now the screws are missing off my phone case which is really heavy case with screws. Do the vibrations make things loose? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-4-21 09:09:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"So you are admitting to having a screw loose. We already knew you were coming apart. ","replyToPid":0}
回复 支持 6 反对 0
发表于 2021-4-21 09:00:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't identify as a bottle and I scrěw in the truck.","replyToPid":0}
发表于 2021-4-21 09:23:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Probably have 100 bottle caps in here","replyToPid":0}
GMT+8, 2026-2-10 14:04 , Processed in 0.066690 second(s), 24 queries .
