查看: 205|回复: 7
Tire size difference
 楼主| 发表于 2021-4-18 07:24:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi Friends , Whats a difference between 295/75/22.5 Bridgestone and 275/80/22.5 Michelin for drives.\nDo they make any mileage difference on odometer.\nAny recomendations, my steers are 295/75/22.5 Bridgestone.\nThanks.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-4-18 07:40:22 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"295 is the width in millimeters, 75 is the aspect ratio( the side wall of the tire is 75% of the width =221.25 mm). The 22.5 is the diameter for the rim. The only discernible difference in these tires is in the width. The 295 is almost an inch wider. "}
发表于 2021-4-19 01:25:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"the above numbers you are asking about are the width of tires then height of sidewall then rim diameter.","replyToPid":0}
发表于 2021-4-18 07:29:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"no difference. They are exactly the same size manufacturers just use different numbers.\nthey are both low pro 22.5.","replyToPid":0}
发表于 2021-4-18 08:09:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you install different tires they will wear uneven ","replyToPid":0}
发表于 2021-4-18 07:40:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"The 275's are 20mm, or 13/16ths of an inch narrower.  The overall diameter is 1/10th of an inch smaller on the 275's and will only effect your speedometer .03%. So No difference really","replyToPid":0}
 楼主| 发表于 2021-4-18 17:20:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you all for the information.","replyToPid":0}
 楼主| 发表于 2021-4-18 17:34:10 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"After reading your views 295/75 are wider in width and 275/80 are little higher in height. Am I right ? So I beleive 275 will have better fuel mileage as well."}
GMT+8, 2026-2-10 12:38 , Processed in 0.061637 second(s), 25 queries .
