查看: 402|回复: 11
Dot testing
 楼主| 发表于 2021-4-18 06:51:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just had my 2nd random in 3 months. Is this normal? Also is it possible to be brought in on rumors or other drivers talking crap or telling dispatch you drink or use. I’ve been driving just over a year and I’m gonna 10 yrs sober in may so not worried about being dirty just curious as to why ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-4-18 06:54:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"No it's not.  Randoms are done quarterly.  Someone is out to get you."}
发表于 2021-4-18 21:59:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"When I worked for a larger company, I got tested three times in a month. And 2 of those were in the same week. I thought the same thing as you but they proved to me that DoT pulls random socials and tells the company to test this person. Then you are back in the pool again.","replyToPid":0}
发表于 2021-4-18 11:35:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"quick fix and a microwave. problem solved. Puff puff pass 420 coming up soon😂🙊🙉🙈","replyToPid":0}
发表于 2021-4-18 07:21:25 来自手机 | 显示全部楼层
936953 发表于 2021-04-17 23:07:09 Randoms are not done quarterly. Your name goes right back into the pool, so it is possible to be called twice in a few months.
","text":"That's the way my drug consortium works as I'm not a company driver. Randoms are pulled once a qtr.  Yes if you are called your name goes back into the bag eligible for next qtr.","replyToPid":423003}
发表于 2021-4-18 07:30:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"buy a whizzinator!","replyToPid":0}
发表于 2021-4-18 07:07:09 来自手机 | 显示全部楼层
1034056 发表于 2021-04-17 22:54:54 No it's not.  Randoms are done quarterly.  Someone is out to get you.
","text":"Randoms are not done quarterly. Your name goes right back into the pool, so it is possible to be called twice in a few months.","replyToPid":423001}
 楼主| 发表于 2021-4-18 11:26:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks. Appreciate the feed back ","replyToPid":0}
发表于 2021-4-18 07:22:16 来自手机 | 显示全部楼层
823934 发表于 2021-04-17 23:16:15 it's normal I got tested twice in a month. just be always ready
","text":"dude twice in a month is not normal.","replyToPid":423004}
发表于 2021-4-18 07:16:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's normal I got tested twice in a month. just be always ready","replyToPid":0}
发表于 2021-4-18 09:13:20 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Happened same with my friend, later he finds out that its the company for which he was working, his company keeps recommending him to random test to authority. As my friend mentioned during his joining that he usually drinks."}
GMT+8, 2026-4-17 20:19 , Processed in 0.136699 second(s), 24 queries .
