查看: 402|回复: 9
Microwave in Peterbilt 389
 楼主| 发表于 2021-3-26 08:02:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’ve got a 389 with the 72” flattop sleeper.  The upper compartment over the closet on the passenger side looks perfect for a small microwave.  However I can’t find one small enough to fit based on the advertised external dimensions.  I found several that are 1/8” too wide, and one that fits the width but is 1/8” too tall.  However it does look like if I pull the plastic trim off I could get the 1/8” I need to get the microwave in then reinstall the trim.  So I have two questions.  1) if anyone has found a microwave that fits in that space can you tell me what brand and model it is?  2). Does anyone know how to pull the trim piece off that cubby?  There aren’t any visible screws, and I tried pulling pretty hard on it thinking it might just be held in my clips and it didn’t move. \n\nThanks!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-3-26 09:39:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can pull that trim piece off all you want and put it back but did you give any thought to how you were going to open and close that microwave. Most of the time that door is the same size.","replyToPid":0}
回复 支持 2 反对 3
发表于 2021-3-26 10:21:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lol red muffy","replyToPid":0}
发表于 2021-3-26 10:18:33 来自手机 | 显示全部楼层
1063552 发表于 2021-03-26 01:39:38 You can pull that trim piece off all you want and put it back but did you give any thought to how you were going to open and close that microwave. Most of the time that door is the same size.
","text":"red muffy definitely knows a lot from the passenger side","replyToPid":420859}
发表于 2021-3-26 08:26:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.raneystruckparts.com/whirlpool-countertop-truck-microwave-oven/","replyToPid":0}
 楼主| 发表于 2021-3-26 10:32:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks.  That whirlpool is one of the ones I’ve been looking at, but according to the published dimensions it is 1/8” too tall.  Do you know for sure it fits in the Peterbilt 389 cubby?","replyToPid":0}
 楼主| 发表于 2021-3-30 02:40:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m going to go ahead and order the Whirlpool unit from Raneys, and hope it fits.  I’ll update this post and let everyone know what I find out.","replyToPid":0}
 楼主| 发表于 2021-4-9 06:23:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well, the whirlpool microwave came in and I tried it today.  Unfortunately it doesn’t fit.  The dimensions on whirlpools website are spot on and it is 1/8” too tall.  The feet are just stamped into the bottom sheet metal so no options there either.  It does fit under the bunk, and I have an outlet under there with the inverter, so I guess I’ll leave it under the bunk, at least for the time being.","replyToPid":0}
 楼主| 发表于 2022-2-13 08:16:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"I thought I would update this post with some additional information with the hope that it might help someone else out.  I did end up buying the whirlpool from Raneys.  \nhttps://www.raneystruckparts.com/whirlpool-countertop-truck-microwave-oven/\n\nBut, it does not fit in the space above the closet in a Pete 389 flat top.  And I later found that it does not run on an inverter.  I tried the factory installed Xantrex and also a Cobra.  So I ended up purchasing a Contoure RV-780B.  https://www.rvupgradestore.com/Contoure-0-7-Cu-Ft-RV-Microwave-Black-p/07-0506.htm?gclid=CjwKCAiAz--OBhBIEiwAG1rIOgL1dKWUrGZeXg-a0-z_TWpH8RJPFV0uMbjSr3S57ZMEaQKet6DA6RoCMm0QAvD_BwE.  The Contoure fits perfectly above the closet and runs on the Xantrex 1800 w inverter.","replyToPid":0}
发表于 2022-2-13 19:28:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I got a 2020 kenworth and this one works for me! \n\nMy wife and I got it at a bed bath & beyond store: Farberware. Model FMO07ABTBKA. 1050w. Length 17” width 13” height 10”. \n\nIf you get it let me know if it works for you! You can always keep the receipt and return it! ","replyToPid":0}
GMT+8, 2026-4-16 03:14 , Processed in 0.136024 second(s), 25 queries .
