查看: 387|回复: 12
Egr
 楼主| 发表于 2021-3-26 06:09:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Decided to delete my egr from my truck. 07 Isx Cummins egr valve. What are the pros of deleting it? And would my pyro temperature change? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-3-26 06:47:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"How many times are you going to ask the same questions?","replyToPid":0}
禁止发言
发表于 2021-3-26 06:51:48 来自手机 | 显示全部楼层
发表于 2021-5-23 23:40:08 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If you’re going to go through all that trouble, why not sell the truck and get yourself a pre-2000 truck? You’ll be legal and be allowed to run a paper log book, but yeah, you cannot legally enter CA.\n\nThe other option is to buy a new truck and get rid of it around 350k miles. I personally never had aftertreatment check engine lights with newer trucks. Those problems are mostly an issue for older trucks. Newer trucks also have less problems with the aftertreatment.\n\nI’m starting to believe that the best way to be more profitable in trucking is to buy a new truck cash, use it for about 350k (like mega fleets), and sell it yourself for market value or higher since your truck won’t be from a mega company. Too much money is lost when the truck is in the shop and not being able to work. Then you’ll be leaving with a bill in the thousands. It’s very common. "}
发表于 2021-3-30 21:41:04 来自手机 | 显示全部楼层
582412 发表于 2021-03-29 17:33:06 technically it's only illegal depending on the legal emission standards of your state. if the state your truck is registered in has limited or no emissions you can delete and other states have to observe the states regulations in which you are registered.
","text":"No, it’s illegal under Federal emissions laws","replyToPid":421205}
发表于 2021-3-30 01:33:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"technically it's only illegal depending on the legal emission standards of your state. if the state your truck is registered in has limited or no emissions you can delete and other states have to observe the states regulations in which you are registered.","replyToPid":0}
 楼主| 发表于 2021-3-27 09:05:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t have the dpf, I just have the egr valve , it’s about 1500 to delete, and yes i just run a couple days a week ","replyToPid":0}
发表于 2021-3-26 06:53:03 来自手机 | 显示全部楼层
766797 发表于 2021-03-25 22:39:54 it's illegal, no dealers will repair it...
","text":"yup.  already told him that","replyToPid":420835}
发表于 2021-5-25 11:20:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s an 2007. It should be pre-emission!!!","replyToPid":0}
发表于 2021-3-27 03:20:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Here's my advice,  if you're on the money contract Freight, special haul etc keep the Def you're probably a few that can afford it with that age truck.  Now if you're running the up n down spot market I would delete it so you can put more money in your pocket along with better miles per gallon n horse power..  True, you may not be able go to every dealer but small town dealers usually don't say anything just be specific on what you won't done...no problems, and of course local shops don't even care.  Expect to pay $2500 for delete.","replyToPid":0}
发表于 2021-3-26 06:52:22 来自手机 | 显示全部楼层
936953 发表于 2021-03-25 22:47:07 How many times are you going to ask the same questions?
","text":"haha","replyToPid":420837}
发表于 2021-5-23 22:11:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Egr delete not a huge difference, a little more power to the wheels a little better on the fuel mpg, just make sure the people that are doing it put a block plate on the egr cooler because if it fails (and they do) you'll end up with a bunch of coolant in your engine, isx made a pre egr engines you can also look to then to swap egr parts, you'll probably be running that software too so shouldn't be a problem. I wouldn't worry about dealers working on it given that's a 2007 and a Cummins I bet you dont take it to any dealer to begin with. ","replyToPid":0}
GMT+8, 2026-4-17 18:15 , Processed in 0.108517 second(s), 24 queries .
