查看: 369|回复: 8
Weight
 楼主| 发表于 2021-3-22 21:35:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just bought a Peterbilt  with the steers weight of 13000 LB would I have a problem with DOT?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-3-22 21:57:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"No... i drive a pete and it a heavy one too... 13,750 on steers... EMPTY... ! just slide 5th wheel back  a couple teeth and you should be good.","replyToPid":0}
发表于 2021-3-22 22:11:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look on your sticker located on the drivers door jamb. Make sure the axle is rated for 13k, then make sure the tires are rated for 13k. Then rock on. Obviously factory tires will be properly rated, but if someone cheaped out with new tires they might not be rated properly.","replyToPid":0}
1万
发表于 2021-3-22 22:08:01 来自手机 | 显示全部楼层
208374 发表于 2021-03-22 13:57:21 No... i drive a pete and it a heavy one too... 13,750 on steers... EMPTY... ! just slide 5th wheel back  a couple teeth and you should be good.
","text":"how big is that hood ornament ??? 😉\nsounds like we're talking about some real trucks...","replyToPid":420514}
发表于 2021-3-23 22:07:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Heavy but ya gotta love a... \" KITTY MOTOR \" !!! Mine is on catnip","replyToPid":0}
禁止发言
发表于 2021-3-23 00:56:05 来自手机 | 显示全部楼层
发表于 2021-3-23 00:12:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok I know a guy with same name in TN ","replyToPid":420537}
发表于 2021-3-22 23:09:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Where you from ray?","replyToPid":0}
 楼主| 发表于 2021-3-22 23:41:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Arizona ","replyToPid":0}
GMT+8, 2026-4-17 18:14 , Processed in 0.109184 second(s), 24 queries .
