查看: 945|回复: 10
NEED HELP
 楼主| 发表于 2021-3-16 15:06:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone know someone who gives backing lessons for semi trailers?  I really need some help in backing!! ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2021-3-16 17:07:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I guess they really don't need help because they never said where they are ? 👹👽👺","replyToPid":0}
1万
发表于 2021-3-17 18:53:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"does your truck have ABS ? automatic backing system this is probably the greatest invention, the only problem is new drivers never learn how to back up. 👍😉🇺🇸\ndo u have a CDL ? \nhow did you get it if you can't back up ?\nif you have all that, then you need to practice practice and more practice..."}
发表于 2021-3-16 15:57:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I can where you from ","replyToPid":0}
发表于 2021-3-18 01:02:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just practice over and over that's how ya learn. ","replyToPid":0}
 楼主| 发表于 2021-3-18 09:08:13 来自手机 | 显示全部楼层
625579 发表于 2021-03-17 17:02:09 Just practice over and over that's how ya learn.
","text":"Thanks. I have backed up, however, I was taught a 45 45 90. But out at the docks... there isn’t enough room in front to use that backing technique. ","replyToPid":420163}
发表于 2021-3-18 11:35:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"youtube : my trucking skills (great channel to watch and study)","replyToPid":0}
 楼主| 发表于 2021-3-17 12:19:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"I am in Texas.  By Laredo","replyToPid":419984}
 楼主| 发表于 2021-3-18 09:10:10 来自手机 | 显示全部楼层
1031233 发表于 2021-03-17 10:53:49 does your truck have ABS ? automatic backing system this is probably the greatest invention, the only problem is new drivers never learn how to back up. 👍😉🇺🇸\ndo u have a CDL ? \nhow did you get it if you can't back up ?\nif you have all that, then you need to practice practice and more practice...
","text":"I can back up, however, it takes me 4 ever. I was taught a 45 45 90. At the docks I go to, I have been running into the problem of not enough room for the backing technique—- that’s where I get into trouble.  No ABS on this truck. ","replyToPid":420109}
发表于 2021-3-18 10:31:13 来自手机 | 显示全部楼层
1049898 发表于 2021-03-18 01:10:10 I can back up, however, it takes me 4 ever. I was taught a 45 45 90. At the docks I go to, I have been running into the problem of not enough room for the backing technique—- that’s where I get into trouble.  No ABS on this truck.
","text":"45 45 90 I can only do that with doubles","replyToPid":420223}
GMT+8, 2026-4-19 18:54 , Processed in 0.111237 second(s), 24 queries .
