查看: 419|回复: 10
CBD oil
 楼主| 发表于 2021-3-15 10:13:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good evening guys and gals . I have lower back pain I do stretches not the best results my question is can we take cbd oil? Thank You ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-3-15 11:09:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"A quick Google search and you will find countless stories of drivers failing drug tests after using “zero THC” CBD products. Some losing their careers after decades of driving.","replyToPid":0}
回复 支持 8 反对 0
发表于 2021-3-15 10:32:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nope, even if the label says Zero THC it still has enough to fail the drug test. ","replyToPid":0}
回复 支持 5 反对 1
发表于 2021-3-16 03:27:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Smoke Wèèd Every Day","replyToPid":0}
发表于 2021-3-15 18:10:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"take whatever you want you just need to know how to pass a drug screen. Its simple buy quick fix at smoke shop. if they do hair sample they got shampoo for that also. If they do blood America would be in trouble not much freight would be delivered.","replyToPid":0}
发表于 2021-3-15 10:21:47 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Buy a whizzinator!\nhttps://www.thewhizzinator.com/\nI ėat męth and always pāşş!"}
发表于 2021-3-17 08:20:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have spastic cerebral palsy and cbd oil is recommended a lot. but everyone who recommends it says that it could possibly have traces of thc so I have never tried it. I've never tried any of that stuff even though its supposed to be great for a person like me. im just a gravity mutant. the gravity is probably much lighter on my home planet.","replyToPid":0}
发表于 2021-6-5 08:35:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"oxycodone works the best. Keep a Upass kit on you at all times though for drug test purposes. 😉","replyToPid":0}
发表于 2021-6-5 09:11:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try chiropractor and get massages(cupping). Workout and strengthen your core.  From personal experience. I had a sports injury. Did all this.","replyToPid":0}
发表于 2021-6-5 20:30:02 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"No, you do NOT want medication. You need to find out WHAT is causing the back pain. I’ll put my money in that most back pain problems are a result of being overweight, lack of exercise (particularly poor lower back muscles), and having a sedentary job or lifestyle.\n\nIf you doubt it’s about being overweight, think about this. If you are overweight even just 35 pounds, it would be the equivalent of carrying a 5 gallon water bottle on you 24/7. And that’s just 35 pounds overweight. Some people are way past 35. So if you lose the overweight, your body will be lighter and this will be less pressure on your lower back. On top of that you can also strengthen your lower back muscles by doing a few exercises that target the lower back muscles. However, take it easy, and make sure you can do at least over 20 repetitions per set to avoid hurting your lower back even further. If you’re new, you probably won’t need weights at all. As you build muscles and advance, then you can use (modern quick adjustable) dumbbell weights.\n\nThe two back exercises I do to strengthen my lower back are the stiff-leg dumbbell deadlift and flat sit-ups. The first one can be a bit tricky to distinguish from other similar exercises like the regular deadlift or squat. You probably want to watch several videos to know the differences. Both of these exercises can be done without weights (for beginners). If you cannot do a sit up, you can place pillows behind you to help you or you can use an adjustable bench in the incline position. "}
GMT+8, 2026-4-17 17:08 , Processed in 0.160094 second(s), 24 queries .
