查看: 177|回复: 5
Anyone knows how to disable the SCR/DEF on my Volvo?
 楼主| 发表于 2021-3-14 03:30:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"Having too many SCR problems ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-3-14 03:33:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Crush it. Will fix it right quick. 🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸"}
发表于 2021-3-14 03:41:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cost the same to fix it. Have to get the ECM reprogrammed to disable it. EPA has been cracking down on companies performing the programming. If you’re in limp mode (5mph) unplugging the speed sensor (usually located on the tail shaft of transmission) works on most volvos. Will save you a tow to the shop. I my self gave up on repairing SCR on my peterbilt. I purchased a BullyDog Heavyduty Watch dog, I just shut the light off a couple times a day and roll on.","replyToPid":0}
禁止发言
发表于 2021-3-14 04:15:20 来自手机 | 显示全部楼层
发表于 2021-3-14 10:21:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"unplug the speed sensor of the transmission it's easy to do","replyToPid":0}
发表于 2021-8-11 19:32:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Delete it. No more problems. ","replyToPid":0}
GMT+8, 2026-2-8 12:17 , Processed in 0.062304 second(s), 24 queries .
