查看: 749|回复: 22
Scale weight
 楼主| 发表于 2021-3-13 07:32:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"34200 lbs on the drive axle because of fuel. I was 33720 before. Anybody know if this would be a serious problem at the scale house ? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-3-13 09:35:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"dump the h00ker!","replyToPid":0}
回复 支持 7 反对 0
发表于 2021-3-13 09:29:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just run the scale and hide your prepass","replyToPid":0}
发表于 2021-3-13 12:53:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your steer axle should be overweight for fuel not your drives. Slide your 5th wheel. To be honest I seen people get away with it and other times like the great state of Michigan I seen people get hit for being 100 lbs over. It just all depends on what officer you get and how his day is going!","replyToPid":0}
发表于 2021-3-13 08:11:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your so worried about the scale just go around it","replyToPid":0}
发表于 2021-3-13 07:53:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"200 pounds is about 25 gallons of fuel. If you go 150 miles or so before the scale house you might be fine. You failed to mention any other weights.","replyToPid":0}
发表于 2021-3-15 21:26:17 来自手机 | 显示全部楼层
63718 发表于 2021-03-15 13:13:32 3% overgross not overaxle
","text":"You can’t be 3% over gross without being over axle. If you look at your motor carrier atlas every state is 80k not 80k plus 3%. If you’re running on an annual permit usually a state will have a % you can be over. My state is 100k plus 5% I believe this is where the confusion comes from.","replyToPid":419874}
发表于 2021-3-14 00:46:21 来自手机 | 显示全部楼层
1084567 发表于 2021-03-13 01:28:30 Drive past the scale. I do it 80% of the time
","text":"But you're in a Prevost 😂","replyToPid":419676}
 楼主| 发表于 2021-3-13 21:34:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"No ","replyToPid":419664}
1万
发表于 2021-3-13 14:00:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends what state, some states allow for more tolerance than others.","replyToPid":0}
发表于 2021-3-13 07:51:40 来自手机 | 显示全部楼层
1082314 发表于 2021-03-12 23:42:05 So from what I understand you are allowed 3% on 80000 lbs which is 2400 lbs where that is allowed to be I don’t know but legal wise they are supposed to allow that
","text":"80k is 80k there’s no grace period.","replyToPid":419663}
发表于 2021-3-13 07:42:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"So from what I understand you are allowed 3% on 80000 lbs which is 2400 lbs where that is allowed to be I don’t know but legal wise they are supposed to allow that","replyToPid":0}
禁止发言
发表于 2021-3-13 07:42:19 来自手机 | 显示全部楼层
发表于 2021-3-13 08:09:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hey my bad then! But just saying I have friends doing that maybe it’s more ag","replyToPid":0}
发表于 2021-3-13 08:10:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"I guess I should look it up to make sure","replyToPid":0}
发表于 2021-3-13 09:28:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drive past the scale. I do it 80% of the time ","replyToPid":0}
GMT+8, 2026-4-15 17:56 , Processed in 0.112338 second(s), 25 queries .
