查看: 455|回复: 22
Egr
 楼主| 发表于 2021-3-6 22:42:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anybody deleted a egr? What the pros and cons of it? I’m driving an 07 Isx Cummins ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-3-7 03:50:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"It costs as much to delete it as it does to fix it. No reputable shop will work on deleted truck.","replyToPid":0}
发表于 2021-3-7 09:00:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"No downside if you know a good shade tree mechanic and you don’t run in commyfornia. \n    Better power, fuel economy, and longevity. \nOne guy put 3,000,000 miles on a deleted 14L series 60 ","replyToPid":0}
发表于 2021-3-7 06:33:30 来自手机 | 显示全部楼层
936953 发表于 2021-03-06 19:50:47 It costs as much to delete it as it does to fix it. No reputable shop will work on deleted truck.
","text":"I'm an unreputable shop","replyToPid":419012}
发表于 2021-3-10 00:33:16 来自手机 | 显示全部楼层
147103 发表于 2021-03-08 03:39:35 My Pete had egr valve issues from day I bought it. Egr valves need regular cleaning because of carbon build up. Sometimes it would stick open.  Thus it wouldn't build boost. I unhooked mine. it ran just fine for 5 yrs after that. However check engine light stays on.
","text":"and I must thank you old Marine cuz you're the one that told me about unplugging that things run fine from that day on 81 in Tennessee year or so ago","replyToPid":419129}
发表于 2021-3-8 11:45:11 来自手机 | 显示全部楼层
","text":"I see,well hey maybe he should try it. I think I’d flash the computer though to get rid of the check engine light at some point and time though","replyToPid":419129}
禁止发言
发表于 2021-3-8 03:26:53 来自手机 | 显示全部楼层
发表于 2021-3-7 09:15:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sorry, In IL","replyToPid":0}
发表于 2021-3-7 09:12:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"It can get touchy!!! Jersey is the East coasts california other than that.... better fuel efficiency no terrible de rated power,a lot of headaches kinda just go away! And actually a bit of science here..... the burn off that the newer trucks go through on regen is actually more harmful than the more opened up version. Do your own research! But they will never tell you that. Simply running a pre emissions model is better but becoming harder and harder to do! 😢 unfortunately the good ole days are coming to a close! I wish I would have been a trucker about 35 years ago ","replyToPid":0}
发表于 2021-3-7 09:07:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"I know of a lot of really good mechanics that will work on and do these kinds of things ","replyToPid":0}
发表于 2021-3-7 04:43:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"The engine can actually breathe, run cooler, and will last longer.  Like mentioned, most shops won't touch it.","replyToPid":0}
发表于 2021-3-7 03:52:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I like it save on diesel and I don’t have to keep going to the dealer for after treatment codes and chasing f$&@k sensors. Make sure you get a good tech to program. Remember more power more diesel.","replyToPid":0}
发表于 2021-3-7 09:15:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"So my friend got his deleted IL for 1800 and do redo the filters and Jazz was gonna be 10000 and he said can’t afford that so they did the delete","replyToPid":0}
GMT+8, 2026-4-18 00:52 , Processed in 0.142760 second(s), 24 queries .
