查看: 254|回复: 12
Help me find an A/C solution without idle
 楼主| 发表于 2019-6-7 00:54:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"I may have posted this already. If I have, my bad. I have a carrier that wont blo*w cold but will bl*w hot and randomly turn off. When its simply on, it’ll run all night. Just put a new starter and belt in it. Mechanic is saying it could be alternator which would run me thousands but he isn’t certified so I should have a dealer diagnose it. Im looking at dumping more money into it or getting a new one for 8-13k. Its a 15 Freightleiner. I dont want to idle the truck. Any suggestions on what to do? Or alternatives? Much appreciated.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-7 01:11:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"What does a starter or belt or alternator have to do with a/c. Or am I missing something? And u said carrier so r we talking about ur truck or reefer?","replyToPid":0}
发表于 2019-6-7 02:55:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"my thermoking was randomly shutting off. the ac, fan and heat. At a friend's advice I started shutting down the system when I started to drive instead of letting the override shut it down. That seemed to help. still does it now and then but less. He said, if you don't shut it off, fuel stays in the system so it gums things up. it took a while of me shutting it down for things to improve. It was having a hard time turning on the APU, too.  i had to get the apu started with an appliance, then atter it started i could unplug it. repair guy couldn't fix an intermittent error he said. I feel your pain.","replyToPid":0}
发表于 2019-6-7 01:43:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thousands?!? Good grief! What's he installing, solid gold parts?? An alternator wont fix that issue. Please explain more clearly...","replyToPid":0}
发表于 2019-6-7 03:50:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"1) an alternator isn’t thousands. When I had mine replaced in my carrier APU, I want to say it wasn’t more than $300, parts&labor. \n\n2) is the A/C shutting down the whole APU or just the HVAC? Like QueenofTruckin said, it could be your temperature sensor which is an easy, cheap fix. If it’s just HVAC shutting down, mine was a breaker on the board and was around $500 to replace the whole board","replyToPid":0}
 楼主| 发表于 2019-6-7 04:31:42 来自手机 | 显示全部楼层
654793 发表于 2019-06-06 17:11:58 What does a starter or belt or alternator have to do with a/c. Or am I missing something? And u said carrier so r we talking about ur truck or reefer?
","text":"Truck. I just wanted to convey what has been done to the APU. The alternator part Im passing on from my mechanic. As an aside I don’t much know about engines or mechanics of that sort; hence, why I am here. Any constructive input is very much appreciated.","replyToPid":57103}
 楼主| 发表于 2019-6-7 04:32:16 来自手机 | 显示全部楼层
707101 发表于 2019-06-06 17:43:39 Thousands?!? Good grief! What's he installing, solid gold parts?? An alternator wont fix that issue. Please explain more clearly...
","text":"What else would you want to know? Any information you need Id be glad to give.","replyToPid":57132}
 楼主| 发表于 2019-6-7 04:32:42 来自手机 | 显示全部楼层
607385 发表于 2019-06-06 18:14:50 idk if this will help but happened to me before it was my temperature something ( shoot 6 years ago) was throwing everything off
","text":"What do you mean your temperature? Thanks btw","replyToPid":57189}
 楼主| 发表于 2019-6-7 04:33:21 来自手机 | 显示全部楼层
678033 发表于 2019-06-06 18:55:26 my thermoking was randomly shutting off. the ac, fan and heat. At a friend's advice I started shutting down the system when I started to drive instead of letting the override shut it down. That seemed to help. still does it now and then but less. He said, if you don't shut it off, fuel stays in the system so it gums things up. it took a while of me shutting it down for things to improve. It was having a hard time turning on the APU, too.  i had to get the apu started with an appliance, then atter it started i could unplug it. repair guy couldn't fix an intermittent error he said. I feel your pain.
","text":"Thank you","replyToPid":57268}
 楼主| 发表于 2019-6-7 04:34:18 来自手机 | 显示全部楼层
668141 发表于 2019-06-06 19:50:08 1) an alternator isn’t thousands. When I had mine replaced in my carrier APU, I want to say it wasn’t more than $300, parts&labor. \n\n2) is the A/C shutting down the whole APU or just the HVAC? Like QueenofTruckin said, it could be your temperature sensor which is an easy, cheap fix. If it’s just HVAC shutting down, mine was a breaker on the board and was around $500 to replace the whole board
","text":"Yea the whole thing shuts down. It looks like from what you guys are saying, just get it diagnosed cause its not nearly as expensive as what Im being told. Thanks boss.","replyToPid":57315}
GMT+8, 2026-4-18 09:38 , Processed in 0.536636 second(s), 24 queries .
