查看: 239|回复: 13
2015 Cascadia pulls to the right!!!!
 楼主| 发表于 2019-6-7 00:32:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"I hope there is someone here who can help. I have spent alot of money to find a problem and still nothing.  Truck was pulling to the right and pulling a steering wheel. I did 3 aligments and everyone said that everything was good.  I changed following: All new shocks, Torque rods, Steering gear box, Front Leaf Springs, leveler, Shocks on the cab, new Tires and  i really do not know what to do next. I would really appriciate if someone has any idea. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-7 04:53:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are your slack adjusters adjusted properly? Freightliner I was driving did the same and it turned out only 2 brakes on tractor were actually doing their job.","replyToPid":0}
 楼主| 发表于 2019-6-7 00:57:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes they did all 3 times","replyToPid":0}
发表于 2019-6-7 01:08:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Does it pull to the right when ur bobtail?","replyToPid":0}
 楼主| 发表于 2019-6-7 01:14:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"It has nothing to do with the trailer. chaneged 3 different trailers and Bobtail. Still pulling.","replyToPid":0}
 楼主| 发表于 2019-6-7 01:21:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"well easy for you to say, you didnt give 70k for the truck ","replyToPid":0}
发表于 2019-6-7 01:28:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do u have any tires wearing more then the others or in a strange way? ","replyToPid":0}
发表于 2019-6-7 01:49:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"if u spent 70k on a truck and replaced all that stuff and did an alignment 3 times maybe its time 4 a new mechanic just my opinion","replyToPid":0}
发表于 2019-6-7 02:04:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m wondering if he expects the truck to go laser straight. I don’t think I’ve ever driven a truck that does. ","replyToPid":0}
 楼主| 发表于 2019-6-7 04:53:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can't tell by theyou can't tell by the tires coz they are new. And for Log book it's not that I am expecti g the truck to go straight the peoblem is when it pulls the right pulls the stearing wheel which makes me over steer all the time.","replyToPid":0}
GMT+8, 2026-3-20 22:42 , Processed in 0.116171 second(s), 24 queries .
