查看: 113|回复: 2
found this Google it
 楼主| 发表于 2021-3-4 00:33:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"look for section g.  but this will help you if you are a owner operator. \n\n49 CFR § 376.12 -\n\nhttps://www.law.cornell.edu/cfr/text/49/376.12","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-3-4 04:59:42 来自手机 | 显示全部楼层
{"replyTo":"","text":" 9 U.S. Code Title 9— ARBITRATION is another good one\n\nThe FAA requires courts to enforce arbitration agreements, but it does not apply to “contracts of employment” with seamen, railroad employees, and other workers engaged in foreign or interstate commerce. 9 U.S.C. ... This is commonly referred to as the “transportation worker exception” or exemption of the FAA.","replyToPid":0}
发表于 2021-3-4 05:08:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"hahaha seamen!","replyToPid":0}
GMT+8, 2026-4-18 00:51 , Processed in 0.091486 second(s), 24 queries .
