查看: 253|回复: 21
They spread a lie hoping you don't keep up with "real-news" and thats how lying works. You "revise" your lie...
 楼主| 发表于 2021-3-2 23:41:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"newsweek.com","videos":"[]","link":"{\"picture\":{\"description\":\"\",\"height\":2000.0,\"name\":\"\",\"url\":\"https://d.newsweek.com/en/full/1743179/texas-governor-greg-abbott.jpg?w=790&f=5a117be4586728f0d3a59c298a1288ba\",\"width\":3000.0},\"title\":\"Greg Abbott Admits Failure from All Power Sources After Initially Blaming Green Energy\",\"type\":\"GENERAL\",\"url\":\"https://www.newsweek.com/greg-abbott-admits-failure-all-power-sources-after-initially-blaming-green-energy-1571931\",\"valid\":true}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-3-3 00:12:57 来自手机 | 显示全部楼层
1086724 发表于 2021-03-02 15:43:13 while no one is listening. Green energy is the future and the path to sustainability, stoopid hillbilly.
","text":"fossil fuels will always ve the answer.","replyToPid":418554}
回复 支持 6 反对 1
 楼主| 发表于 2021-3-2 23:43:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"while no one is listening. Green energy is the future and the path to sustainability, stoopid hillbilly.","replyToPid":0}
回复 支持 0 反对 6
发表于 2021-3-3 00:42:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"show us your shrıne to a.o.c.","replyToPid":0}
发表于 2021-3-3 00:17:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fix California 1st beener","replyToPid":0}
发表于 2021-3-3 07:03:39 来自手机 | 显示全部楼层
1086724 发表于 2021-03-02 19:02:53 Think little brain...weaning off fossil fuels doesn't mean the elimination of all oil products. The less oil we burn into the atmosphere, the better for our environment. It's the same reason we don't just dump oil on the ground when we do an oil change.
","text":"Little brain huh?  I’m not the one looking to hookup with drivers at truckstop. Your post says it all.  My little F~ag","replyToPid":418592}
 楼主| 发表于 2021-3-3 03:02:53 来自手机 | 显示全部楼层
1073265 发表于 2021-03-02 18:45:58 Before you run your mouth little man. Read what items come from fossil fuel
","text":"Think little brain...weaning off fossil fuels doesn't mean the elimination of all oil products. The less oil we burn into the atmosphere, the better for our environment. It's the same reason we don't just dump oil on the ground when we do an oil change.","replyToPid":418586}
回复 支持 0 反对 3
发表于 2021-3-3 02:40:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you driving a electric truck now???  ","replyToPid":0}
发表于 2021-3-3 02:45:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Before you run your mouth little man. Read what items come from fossil fuel","replyToPid":0}
发表于 2021-3-3 06:10:07 来自手机 | 显示全部楼层
{"replyToPid":418592,"replyTo":"
","text":"Even though the oil came from the ground in the first place. And most good water purification filters are made from carbon, which is easy to generate by burning diesel "}
发表于 2021-3-3 00:18:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tell everyone about your sewer","replyToPid":0}
发表于 2021-3-2 23:55:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.americasquarterly.org/article/mexicos-messy-reckoning-with-racism/","replyToPid":0}
发表于 2021-3-2 23:55:29 来自手机 | 显示全部楼层
发表于 2021-3-2 23:55:44 来自手机 | 显示全部楼层
发表于 2021-3-2 23:55:51 来自手机 | 显示全部楼层
发表于 2021-3-2 23:56:15 来自手机 | 显示全部楼层
发表于 2021-3-3 00:02:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://youtu.be/j73cjA1IcJw","replyToPid":0}
GMT+8, 2026-4-20 15:02 , Processed in 0.104593 second(s), 24 queries .
