查看: 216|回复: 5
tripac thermo king
 楼主| 发表于 2021-2-27 13:06:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just bought my truck and mi tripac works great as heater.  but when I tried to use the A/C it worked like 5 minutes than stopped and a yellow warning ⚠️ came on. \nanybody experienced this and it could be?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":954.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true,"externalShare":false}
发表于 2021-2-27 21:24:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"#1 reason is the fan on the back of the sleeper didn’t kick on, usually a blown fuse in the control box under the bunk. There was a service bulletin to replace the 20 amp with a 30 amp.\n     If not, possibly low on refrigerant, kicking off on low pressure. ","replyToPid":0}
回复 支持 6 反对 0
发表于 2021-3-1 17:06:39 来自手机 | 显示全部楼层
936953 发表于 2021-02-27 13:24:04 #1 reason is the fan on the back of the sleeper didn’t kick on, usually a blown fuse in the control box under the bunk. There was a service bulletin to replace the 20 amp with a 30 amp.\n     If not, possibly low on refrigerant, kicking off on low pressure.
","text":"Yup check the fuse, once replaced, go inspect the radiator on the condensor fan, if it's clogged up with dirt and dust, get it wet and blow it out with an air tool\n\nbeen having this problem since I got the Tri Pac Evolution","replyToPid":418341}
发表于 2021-3-2 07:44:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"just another engine to maintain","replyToPid":0}
发表于 2021-3-2 07:43:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"junk","replyToPid":0}
发表于 2021-3-2 00:26:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"step 1, don't take technical advice from truckers unless you trust them with your life.\nstep 2, if you have no technical knowledge, take it to a thermo king shop.\n\nstep3, it could be anything, plug the ethernet cable from the main box into a laptop and pull the trouble code.","replyToPid":0}
GMT+8, 2026-2-5 13:00 , Processed in 0.068580 second(s), 24 queries .
