查看: 255|回复: 4
Trip planning
 楼主| 发表于 2021-2-26 13:29:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"whats the best route to take leaving from Rogersville, TN headed to Reno Nevada?  any suggestions...","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-27 09:28:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"google will screw you.  no vaseline.  no reach around.  not even a kiss.\n\ndo better.\n\nand on that route, i quote someone ir other when i suggest: \"Go WEST, young man.\"","replyToPid":0}
发表于 2021-3-1 02:44:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"@Rokk59\nIt’s good to use truck routing apps such as ‘CoPilot Truck’ and ‘MileOn’ with ‘TruckerPath.’ MileOn will give a 2D view with IFTA breakdown and truckstop recommendations for your preplan. CoPilot with ActiveTraffic will give you turn by turn / dock to dock directions. TruckerPath will greatly help when needing a plan B at the last hour or two of your HOS. It’s always good to keep that Rand McNally MCA on board too as a back up. 😎👍","replyToPid":0}
发表于 2021-2-26 22:10:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"ax google","replyToPid":0}
发表于 2021-3-26 08:19:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I 24 TO I57 TO I 70 TO I 80","replyToPid":0}
GMT+8, 2026-4-16 10:24 , Processed in 0.103591 second(s), 24 queries .
