查看: 260|回复: 12
Pinion seal
 楼主| 发表于 2021-2-26 05:09:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"New pinion seal and yoke leaking again after one day, anybody had this problem before?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-26 16:48:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Could be a couple things\n-drive shaft isn’t clocked correctly, If it is then it might be clock backwards\n-seal was damaged when installed\n-caged bearings is bad\n-could have a bad drive shaft hanger. \nMost of these things you can check yourself","replyToPid":0}
禁止发言
发表于 2021-2-26 07:29:07 来自手机 | 显示全部楼层
 楼主| 发表于 2021-2-26 07:28:00 来自手机 | 显示全部楼层
147103 发表于 2021-02-25 23:05:20 My 1st step. Go back to shop and complain.  Just don't let them bluff you into repairs truck not need. Definitely check drive shaft balance
","text":"Lol I probably won’t go back over there, they had my truck for two weeks and still couldn’t get it right ","replyToPid":418192}
禁止发言
发表于 2021-2-26 07:05:20 来自手机 | 显示全部楼层
 楼主| 发表于 2021-2-26 06:33:35 来自手机 | 显示全部楼层
147103 发表于 2021-02-25 22:23:22 Did you replace yoke? Did you torque nut?
","text":"Yes I have a new yoke , not sure what they did about the nut ","replyToPid":418185}
发表于 2021-2-26 06:15:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mine leaked too after replacement. Drove 1800 miles to Texas, by the time I made it back it stopped. Brought it back in, they washed it, checked it out. Said it wasn’t leaking. Basically though I was nuts. Haven’t seen a drop since, been over a year now. ","replyToPid":0}
发表于 2021-2-26 06:20:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"The seal is held taught by a spring, it’s not uncommon for the spring to pop out during installation. Any mechanic worth a nickel knows to check that before reasonable of the yoke.","replyToPid":0}
发表于 2021-2-26 05:26:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bad nut not keeping yoke tight or drive shaft need balanced","replyToPid":0}
禁止发言
发表于 2021-2-26 06:23:22 来自手机 | 显示全部楼层
 楼主| 发表于 2021-2-26 06:24:36 来自手机 | 显示全部楼层
936953 发表于 2021-02-25 22:15:08 Mine leaked too after replacement. Drove 1800 miles to Texas, by the time I made it back it stopped. Brought it back in, they washed it, checked it out. Said it wasn’t leaking. Basically though I was nuts. Haven’t seen a drop since, been over a year now.
","text":"It don’t seem as bad as it was before, it just look wet , I’ll wash it down and see if it’s leaking ","replyToPid":418181}
 楼主| 发表于 2021-2-26 06:25:43 来自手机 | 显示全部楼层
936953 发表于 2021-02-25 22:20:28 The seal is held taught by a spring, it’s not uncommon for the spring to pop out during installation. Any mechanic worth a nickel knows to check that before reasonable of the yoke.
","text":"Lol , right. I’ll let someone else look at it if I need to","replyToPid":418183}
 楼主| 发表于 2021-2-26 06:26:30 来自手机 | 显示全部楼层
352112 发表于 2021-02-25 21:26:58 Bad nut not keeping yoke tight or drive shaft need balanced
","text":"I’ll check into it if I need to , ","replyToPid":418175}
GMT+8, 2026-4-17 20:20 , Processed in 0.101828 second(s), 24 queries .
