查看: 185|回复: 18
Paccar engine problems , Kenworth engine, MX-13 engine Coolant probl...
 楼主| 发表于 2021-2-19 04:51:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"youtu.be","videos":"[]","link":"{\"picture\":{\"description\":\"\",\"height\":180.0,\"name\":\"\",\"url\":\"https://img.youtube.com/vi/reRdSYIlusU/mqdefault.jpg\",\"width\":320.0},\"title\":\"YouTube\",\"type\":\"VIDEO\",\"url\":\"https://youtu.be/reRdSYIlusU\",\"valid\":true}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-19 06:12:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you don't see a leak anywhere, the problem is internal. Water pump, head casket, etc.\n\nI bought my truck used and i had a similar problem, after i changed out the computer, no more over heating issues. My guess is they had computer reprogrammed for more power because now i climb hills like old marine runs a mile.","replyToPid":0}
发表于 2021-2-19 06:18:37 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"there is probably a blockage in one of the lines, I've seen this before when the coolant level goes up and down and was bubbling, one of the coolant lines was blocked."}
发表于 2021-2-19 10:39:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"after cat and good cummins engines gone \nkenworth & peterbilt\nno good anymore","replyToPid":0}
发表于 2021-2-19 10:41:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Head gasket will do that. Sometimes you get coolant in the oil other times coolant through the exhaust and others the exhaust goes into cooling system.","replyToPid":0}
发表于 2021-2-19 06:08:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"coolant is under pressure, so it can get hotter than boiling. if you open while hot it will steam.","replyToPid":0}
发表于 2021-2-19 06:45:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"EGR cooler, hopefully ","replyToPid":0}
发表于 2021-2-19 06:11:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks like you overfill steam could of just be from the snow","replyToPid":0}
发表于 2021-2-19 06:26:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"if its a headgasket problem, you will see white smoke out of the exhaust.","replyToPid":0}
发表于 2021-2-19 06:31:05 来自手机 | 显示全部楼层
1081266 发表于 2021-02-18 22:12:03 if you don't see a leak anywhere, the problem is internal. Water pump, head casket, etc.\n\nI bought my truck used and i had a similar problem, after i changed out the computer, no more over heating issues. My guess is they had computer reprogrammed for more power because now i climb hills like old marine runs a mile.
","text":"go read your playgirl magazine.","replyToPid":417515}
 楼主| 发表于 2021-2-19 07:01:46 来自手机 | 显示全部楼层
1081266 发表于 2021-02-18 22:26:19 if its a headgasket problem, you will see white smoke out of the exhaust.
","text":"When it’s cold outside it’s makes white smoke","replyToPid":417522}
 楼主| 发表于 2021-2-19 07:03:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hope it’s still 7 k ","replyToPid":417527}
GMT+8, 2026-2-10 20:12 , Processed in 0.080471 second(s), 24 queries .
