查看: 192|回复: 5
which gear should I use through Wyoming
 楼主| 发表于 2021-2-19 04:43:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"i am driving a 26ft moving truck. should i be using high or low gear going through up and down hills?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-19 06:51:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Doesn’t matter as long as you wear your mask! Covid KILLS! 🙀","replyToPid":0}
发表于 2021-2-19 09:43:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Reverse","replyToPid":0}
发表于 2021-2-19 10:34:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"first ásshole","replyToPid":0}
发表于 2021-2-19 08:04:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Honestly it’s what your comfortable with. Does it have an engine break, if not I wouldn’t be in too high of a gear going down. Up it’s pretty much what your engine will allow."}
 楼主| 发表于 2021-2-19 21:32:50 来自手机 | 显示全部楼层
1080161 发表于 2021-02-19 00:04:54 Honestly it’s what your comfortable with. Does it have an engine break, if not I wouldn’t be in too high of a gear going down. Up it’s pretty much what your engine will allow.
","text":"this moving truck only has low gear, drive, and high gear. we gave been on low and it is working fine. thanks","replyToPid":417546}
GMT+8, 2026-2-4 03:03 , Processed in 0.089126 second(s), 24 queries .
