查看: 351|回复: 13
NEED HELP!
 楼主| 发表于 2021-2-17 02:11:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm on this road in this state and I need to know if this road will be open and if the truck stops and rest areas are open between here and there and where and when I can get fuel. I also need a good shop to change my spark plugs. Thanks for the help! ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2021-2-17 04:59:26 来自手机 | 显示全部楼层
{"replyToPid":417035,"replyTo":"
1079951 发表于 2021-02-16 18:51:53 This comment has been deleted
","text":"This seems to be the typical posts on here on a daily basis"}
回复 支持 7 反对 1
发表于 2021-2-17 02:28:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just keep making left hand turns, you’ll be fine.","replyToPid":0}
回复 支持 6 反对 0
禁止发言
发表于 2021-2-17 02:37:02 来自手机 | 显示全部楼层
 楼主| 发表于 2021-2-18 02:24:01 来自手机 | 显示全部楼层
1071983 发表于 2021-02-17 17:33:01 You should get with the times and make the same post 5 times in a row 😆
","text":"pure genius! 👊😂","replyToPid":417222}
 楼主| 发表于 2021-2-17 06:04:08 来自手机 | 显示全部楼层
929659 发表于 2021-02-16 22:01:08 Oh Driver!!  Be careful!!  that road your on between here and there is terrible!  Everything is shut down.
","text":"I knew it!! Thanks for all the help driver! 😁","replyToPid":417067}
发表于 2021-2-18 03:40:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah, and just for fun, dog leg to the right just to drive your GPS crazy 👍😁👍","replyToPid":0}
发表于 2021-2-17 09:34:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dude don’t u have this app it tells u all this .. u gotta be a typo cyco or just bord tf ??? Crackers","replyToPid":0}
发表于 2021-2-17 06:01:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh Driver!!  Be careful!!  that road your on between here and there is terrible!  Everything is shut down.","replyToPid":0}
1万
发表于 2021-2-17 03:32:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"the mechanic said they forgot to put them on at the factory, I've been driving around with no spark plugs.😀😀😀","replyToPid":0}
发表于 2021-2-17 02:51:53 来自手机
{"replyTo":"","text":"typical millennial hıpster","replyToPid":0}
支持 1 反对 1
49
1万
发表于 2021-2-17 03:30:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I need spark plugs and wires, the mechanic can't seem to find them, he looked all over. 😀👍🇺🇸","replyToPid":0}
GMT+8, 2026-2-10 08:46 , Processed in 0.077821 second(s), 24 queries .
