查看: 67|回复: 5
Texas Power Outage
管理员
Rank: 9Rank: 9Rank: 9
 楼主| 发表于 2021-2-16 23:36:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"Stay safe truckers!\n\nRead on at: https://www.washingtonpost.com/nation/2021/02/16/texas-power-outage-heat/\n\n","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2021-2-17 03:42:32 来自手机 | 显示全部楼层
1080223 发表于 2021-02-16 19:37:56 I see you watched tucker carlson spew out that same garbage. How about billionaires invest in winterized equipment so this failure doesn't happen. You can have oil generators defrost the wind turbines. You can mix the options, but less oil >. Moroff.
","text":"I don't see you driving an electric truck or a wind powered truck put the sails up I'm headed to make believe land.","replyToPid":417042}
发表于 2021-2-17 03:37:56 来自手机 | 显示全部楼层
1031233 发表于 2021-02-16 17:13:10 do we really need more \"green\" energy ?
","text":"I see you watched tucker carlson spew out that same garbage. How about billionaires invest in winterized equipment so this failure doesn't happen. You can have oil generators defrost the wind turbines. You can mix the options, but less oil >. Moroff.","replyToPid":417014}
1万
发表于 2021-2-17 01:52:05 来自手机 | 显示全部楼层
","text":"more proof that so-called \"green energy\" is not reliable,  can't wait for electric trucks... I'll stick with diesel power...","replyToPid":417014}
1万
发表于 2021-2-17 01:13:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"do we really need more \"green\" energy ?","replyToPid":0}
发表于 2021-2-17 01:09:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hāte all yourstūpid pösts al","replyToPid":0}
GMT+8, 2026-2-5 15:26 , Processed in 0.058534 second(s), 24 queries .
