查看: 144|回复: 4
Abs light
 楼主| 发表于 2021-2-16 11:16:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good evening can someone on here really help me I’ve had everything done to the truck for the abs light which is still staying on it’s been to the Freightliner shop four times they keep putting all BS on what they think might be the problem but at the end of the day light is still on. \n                                                    Thank You ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-16 12:12:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have they checked the reluctor ring on the axle position that is giving the problem? If it’s cracked or missing teeth it will keep throwing codes.","replyToPid":0}
发表于 2021-2-16 12:52:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"go to different shops and get different opinions from other techs"}
发表于 2021-2-16 20:12:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"How many times it blinks after taking out the power cord 6-8 times slowly will tell them the issue","replyToPid":0}
发表于 2021-2-17 00:41:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Had same problem on a Pete though. Replaced a speed senor on a drive wheel.","replyToPid":0}
GMT+8, 2026-4-17 21:54 , Processed in 0.088841 second(s), 23 queries .
