查看: 56|回复: 0
A/C issues...again
 楼主| 发表于 2019-1-28 17:02:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"Looking at an older truck with a/c issues. Blows warm air. Had pressures checked, 38 and 250 and its 79 outside and raining. Can only manage a 10 deg drop in temp from outside to inside. This thing was built to use R12 and converted to R134. Expansion valve has been changed because pressures were 5 to 10 and 350.","pics":"[]","canComment":true}
GMT+8, 2026-4-17 08:15 , Processed in 0.060828 second(s), 23 queries .
