查看: 159|回复: 4
Ac/ heater
 楼主| 发表于 2021-2-12 21:22:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"Both my ac and heater is not working. Just blowing the air from outside the truck. Any idea what the problem is? Thanks guys and gals","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-13 06:18:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hit the kill switch and cut back on mines do it also","replyToPid":0}
发表于 2021-2-13 07:39:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your fan motor is shot.","replyToPid":0}
1万
发表于 2021-2-14 02:46:53 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"if your fan motor is running and blowing air, your thermostat might be stuck open and the truck might not be warming up properly... is the water temperature gauge running lower than normal ???"}
1万
发表于 2021-2-14 02:51:40 来自手机 | 显示全部楼层
1031233 发表于 2021-02-13 18:46:53 if your fan motor is running and blowing air, your thermostat might be stuck open and the truck might not be warming up properly... is the water temperature gauge running lower than normal ???
","text":"I tried editing last post, is the fan for the heater motor working ???","replyToPid":416728}
GMT+8, 2026-2-7 15:13 , Processed in 0.049532 second(s), 23 queries .
