查看: 195|回复: 7
Thermo King APU?
 楼主| 发表于 2021-2-9 00:34:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"My APU engine seems to turn off & back on way too frequently. Do you think that my truck batteries are going bad and the APU has to kick on alot to compensate? Running the bunk heater\nTruck Is a 2020","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-9 00:41:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, 2 of mine were bad same situation. If you’re around home Harbor Freight has a battery analyzer for about the same cost as battery check at the T/A","replyToPid":0}
发表于 2021-2-9 02:25:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m currently experiencing the same issue, to the point that my APU won’t can’t keep the batteries charged. ","replyToPid":0}
 楼主| 发表于 2021-2-9 01:02:29 来自手机 | 显示全部楼层
936953 发表于 2021-02-08 16:41:51 Yes, 2 of mine were bad same situation. If you’re around home Harbor Freight has a battery analyzer for about the same cost as battery check at the T/A
","text":"Thank you Sir ","replyToPid":416320}
发表于 2021-2-9 03:02:16 来自手机 | 显示全部楼层
855613 发表于 2021-02-08 18:25:35 I’m currently experiencing the same issue, to the point that my APU won’t can’t keep the batteries charged.
","text":"What’s the charging voltage when APU is running? Should be 13.6-14.1 or close to it. I had to change my alternator. They’re cheap on Amazon direct fit.","replyToPid":416326}
发表于 2021-2-9 11:00:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"go change your battery! bad batteries stresses the alternator and will break it. Compound repairs. A stitch in time saves 9.","replyToPid":0}
发表于 2021-2-10 22:31:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"That happened to me. As soon I changed my batteries it stopped doing it so much frequently. My batteries just needed an replacement cause they got old.","replyToPid":0}
发表于 2021-2-11 12:42:32 来自手机 | 显示全部楼层
","text":"check the the settings on your box inside the cab","replyToPid":416320}
GMT+8, 2026-2-11 00:36 , Processed in 0.103093 second(s), 24 queries .
