查看: 128|回复: 6
suggest a route to Vancouver WA from St. Louis Mo
 楼主| 发表于 2021-2-8 20:41:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"looking at the weather ahead I would like to avoid driving through Wyoming, Colorado,  Idaho. Is there a way that you would suggest to take avoid these states to get to Washington state? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-8 23:52:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Honestly, you just have to research the weather and roll the dice 🎲 .  I70 to I29 to Nebraska 2 to I80 OR I70 to Denver then I25 up to 80\nI70 straight thru Colorado to I15 up to I84. The first option is my usual route, flatter less mountains but is plagued with high winds, blowing snow and frequent road closures. Good luck","replyToPid":0}
发表于 2021-2-9 00:25:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Airplane only way to avoid States you listed going from St Louis","replyToPid":0}
 楼主| 发表于 2021-2-9 03:20:50 来自手机 | 显示全部楼层
597174 发表于 2021-02-08 16:25:25 Airplane only way to avoid States you listed going from St Louis
","text":"ohh no. i can't, i am driving a moving truck with a trailer fot my car. thank you for reply","replyToPid":416316}
 楼主| 发表于 2021-2-9 03:26:56 来自手机 | 显示全部楼层
936953 发表于 2021-02-08 15:52:09 Honestly, you just have to research the weather and roll the dice 🎲 .  I70 to I29 to Nebraska 2 to I80 OR I70 to Denver then I25 up to 80\nI70 straight thru Colorado to I15 up to I84. The first option is my usual route, flatter less mountains but is plagued with high winds, blowing snow and frequent road closures. Good luck
","text":"thank for sharing your routes.  this is very helpful. I feel i will rather take longer that going through the mountains during this time of the year.","replyToPid":416312}
发表于 2021-2-10 06:46:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take i40 across then i5 N","replyToPid":0}
 楼主| 发表于 2021-2-10 21:13:51 来自手机 | 显示全部楼层
357890 发表于 2021-02-09 22:46:51 Take i40 across then i5 N
","text":"glad you mentioned this route. it seems like 10 hours more but less weather issue. have ypu done this route before? how is the traffic?","replyToPid":416405}
GMT+8, 2026-2-7 15:13 , Processed in 0.050035 second(s), 23 queries .
