查看: 168|回复: 3
Suggested alternative route to get to Vancouver WA from St. Louis MO
 楼主| 发表于 2021-2-8 20:40:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"looking at the weather ahead I would like to avoid driving through Wyoming, Colorado,  Idaho. Is there a way that you would suggest to take avoid these states to get to Washington state? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2021-2-10 21:16:49 来自手机 | 显示全部楼层
190599 发表于 2021-02-08 14:11:14 70 to KC.  29 to Sioux Falls, SD. 90 West from there. Best alternative from the Gateway. Check the forecast before you go.
","text":"i am looking this route closely,  it seems that is very up north and through the mountains. i am wondering what makes it for you the best alternative? thanks!","replyToPid":416309}
发表于 2021-2-8 22:11:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"70 to KC.  29 to Sioux Falls, SD. 90 West from there. Best alternative from the Gateway. Check the forecast before you go.","replyToPid":0}
 楼主| 发表于 2021-2-9 03:47:19 来自手机 | 显示全部楼层
","text":"thank you for sharing this route. hope weather gets better next week","replyToPid":416309}
GMT+8, 2026-3-21 00:21 , Processed in 0.094742 second(s), 24 queries .
