查看: 202|回复: 6
Pinion seal
 楼主| 发表于 2021-2-7 23:46:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"How much does it normally cost to replace a pinion seal leak","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2021-2-8 02:36:05 来自手机 | 显示全部楼层
发表于 2021-2-8 00:25:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Seal is cheap, about two hours labor, plus any fluid needed. Some driveshaft can be a pain to get off so could run a little longer. Think I paid around $400 last year. Also if the seal wore a groove in the yoke, that will need to be re placed too. ","replyToPid":0}
 楼主| 发表于 2021-2-8 02:10:44 来自手机 | 显示全部楼层
936953 发表于 2021-02-07 16:25:11 Seal is cheap, about two hours labor, plus any fluid needed. Some driveshaft can be a pain to get off so could run a little longer. Think I paid around $400 last year. Also if the seal wore a groove in the yoke, that will need to be re placed too.
","text":"How much would that be to replace the yoke ? ","replyToPid":416214}
发表于 2021-2-8 02:40:02 来自手机 | 显示全部楼层
1010939 发表于 2021-02-07 18:10:44 How much would that be to replace the yoke ?
","text":"Just the cost of the part, already had to remove it to replace the seal. I don’t know what you drive but $150-$300 range on a Pete","replyToPid":416230}
 楼主| 发表于 2021-2-8 02:55:54 来自手机 | 显示全部楼层
147103 发表于 2021-02-07 18:36:05 I just replaced my yoke and seal. Yoke was 100$ new nut 15$  Seal 50$. I did job myself.
","text":"Thanks ","replyToPid":416236}
 楼主| 发表于 2021-2-8 02:56:10 来自手机 | 显示全部楼层
936953 发表于 2021-02-07 18:40:02 Just the cost of the part, already had to remove it to replace the seal. I don’t know what you drive but $150-$300 range on a Pete
","text":"Thanks, I’m in a 07 Volvo 670 ","replyToPid":416238}
GMT+8, 2026-4-17 21:53 , Processed in 0.086623 second(s), 25 queries .
