查看: 586|回复: 25
best way to keep windshield fluid from freezing?
 楼主| 发表于 2021-2-7 22:28:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"my whipper fluid is frozen and my windshield is now covered with snow from the road. also my windshield fluid mist freezes on my passenger mirror. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-8 01:35:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"alcohol.  I have always added rubbing alcohol and never had problem.","replyToPid":0}
发表于 2021-2-8 00:10:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Jesus you ask a lot of dumb questions","replyToPid":0}
发表于 2021-2-7 22:36:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make sure you’re buying winter fluid good for like -25 degrees. Even with that sometimes the very tip of the spray nozzle may freeze overnight. Grab some hot water and pour over the nozzle. Then there’s always heated wiper blades.","replyToPid":0}
回复 支持 4 反对 1
发表于 2021-2-8 11:14:54 来自手机 | 显示全部楼层
1076269 发表于 2021-02-07 17:12:43 no educational requirement to do this job...
","text":"Tell us about it?? You must be dumbest driver on here. Parking in a no parking zone.🤣🤣🤣🤣. Then ask us to boycott Katy for your ignorance.","replyToPid":416217}
发表于 2021-2-8 00:18:44 来自手机 | 显示全部楼层
1043827 发表于 2021-02-07 16:10:45 Jesus you ask a lot of dumb questions
","text":"😂👍","replyToPid":416212}
发表于 2021-2-8 02:12:15 来自手机 | 显示全部楼层
920151 发表于 2021-02-07 18:01:38 hey I'm from California how was I to know there was none freezing windshield fluid. why not just make all the fluid that way
","text":"The commyfornia part explains the rest of the post. 😂 lol ","replyToPid":416229}
发表于 2021-2-8 01:12:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"no educational requirement to do this job...","replyToPid":0}
 楼主| 发表于 2021-2-8 02:00:36 来自手机 | 显示全部楼层
","text":"no I dont","replyToPid":416212}
 楼主| 发表于 2021-2-8 02:01:38 来自手机 | 显示全部楼层
","text":"hey I'm from California how was I to know there was none freezing windshield fluid. why not just make all the fluid that way","replyToPid":416217}
发表于 2021-2-8 01:22:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"I learned something 👍","replyToPid":0}
发表于 2021-2-7 22:41:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"buy -20 washer fluid at loves 3.99","replyToPid":0}
 楼主| 发表于 2021-2-7 22:43:35 来自手机 | 显示全部楼层
612134 发表于 2021-02-07 14:41:41 buy -20 washer fluid at loves 3.99
","text":"if I add that to my existing fluid will that work","replyToPid":416206}
发表于 2021-2-8 01:59:37 来自手机 | 显示全部楼层
468347 发表于 2021-02-07 17:35:25 alcohol.  I have always added rubbing alcohol and never had problem.
","text":"Until the DOT inspects your truck and they’re low on there monthly quota. Lol ","replyToPid":416222}
GMT+8, 2026-4-16 10:24 , Processed in 0.114495 second(s), 24 queries .
