查看: 226|回复: 8
T680 steering goes right side and shakes . Tires perfect likes new &just done even alignment but still goes right .
 楼主| 发表于 2021-2-6 05:33:44 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-2-6 07:02:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would hope if the kingpins were bad the shop wouldn’t have done the alignment.","replyToPid":416118}
发表于 2021-2-6 11:04:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"brakes","replyToPid":0}
发表于 2021-2-6 05:53:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you balance? If so see if a weight flew off, happened to me","replyToPid":0}
发表于 2021-2-6 06:25:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"kingpins","replyToPid":0}
发表于 2021-2-6 09:07:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"swap your front tires left to right should even out for a while anyway","replyToPid":0}
发表于 2021-2-8 11:58:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the torsion bars.","replyToPid":0}
发表于 2021-2-8 12:15:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hello ","replyToPid":0}
发表于 2021-4-23 14:45:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"shake like that is either a out of round or oblong tire or wheel bearing that's loose from a truck stop or shade tree mechanic that has no idea of how to preload a bearing and pulling to a side after getting the front aligned is the drives are out of alignment!","replyToPid":0}
GMT+8, 2026-4-17 17:54 , Processed in 0.130913 second(s), 24 queries .
