查看: 289|回复: 6
ABS light
 楼主| 发表于 2021-2-4 23:26:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good morning everyone I was on here about two weeks ago talking about my abs light keeps coming on well I had it checked out again I even suggested that they check everything don’t leave no unturned stone well they said went in move some stuff around the computer said everything was fine but that was not the case because when I got in to crank it up the code pop up and the abs light came on so I have to take it back Monday. Feel free to chime in. Thank You ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-4 23:36:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Definitely your flux capacitor ","replyToPid":0}
发表于 2021-2-5 01:51:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I were you I'd check the fuse box under hood near power control module I believe it's a 20 or 30 amp fuse if that's fine then look at power cord (pigtail) from truck to trailer sometimes the plug gets worn and loosens and does'nt get a good contact","replyToPid":0}
发表于 2021-2-5 03:51:01 来自手机 | 显示全部楼层
623393 发表于 2021-02-04 17:51:33 If I were you I'd check the fuse box under hood near power control module I believe it's a 20 or 30 amp fuse if that's fine then look at power cord (pigtail) from truck to trailer sometimes the plug gets worn and loosens and does'nt get a good contact
","text":"Sounds like an intermittent problem, so not the fuse ","replyToPid":415930}
 楼主| 发表于 2021-2-5 07:32:07 来自手机 | 显示全部楼层
1069368 发表于 2021-02-04 16:34:00 need more info  code? tractor? trailer? abs manufacturer?
","text":"2014 Freightliner cascadia ab6-11 code","replyToPid":415904}
发表于 2021-2-5 22:37:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's a wheel sensor fault. 6 is the LR wheel.","replyToPid":0}
发表于 2021-2-12 02:29:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Need to know what the code is first. Then you can know what tire position and etc. have you looked for wheel seal leaks? Any obvious fraying in the abs wiring that goes inside the wheel.","replyToPid":0}
GMT+8, 2026-4-17 21:55 , Processed in 0.071129 second(s), 24 queries .
