查看: 291|回复: 5
Heavy hauler question.. OVERSIZE LOAD
 楼主| 发表于 2021-2-4 13:17:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello I’m a experienced heavy hauler in the state of Michigan.. I have never been given a specific route because I had a cab card and I stayed 150 miles from the terminal so no exact route was given... now I am moved on to bigger and better things with a different company and I’m doing oversized OTR... it’s a whole different ballgame when you have to read permits and obey by the route given... is there anybody that can help me learn how to read routes???? and maybe Introduce me to a GPS that I can adjust my route?? I want to be able to not have to rely on a GPS... I know I’m going to get laughed at but honestly I have a passion for this and I’m trying to be the best I can possibly be.. so please any tips would be great.. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-4 20:20:55 来自手机 | 显示全部楼层
1075045 发表于 2021-02-04 11:59:43 You sound like a noob. Keep that ego in check while you ask for help.
","text":"just because your a intellectually challenge Swift driver. Who spends life as a troll and want to meet drivers at Ta in Ontario California","replyToPid":415877}
回复 支持 6 反对 0
发表于 2021-2-5 22:42:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Believe it or not,  Google Maps is a good tool. Read your route on the permit. When the next road is given, use Maps to find the intersection. The permit normally lists miles between turns. Keep progressing through the steps, make notes on your permit. Whenever you make the next step on the permit, cross it off.","replyToPid":0}
发表于 2021-2-4 18:07:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to add stops on your trip in GPS. This is probably closest you can to “adjusting” your route. If your permit says exit for route 1,\nPick a point along route 1 and add as a stop so it will route down route  1. Then the next turn repeat. It will be time consuming.","replyToPid":0}
发表于 2021-2-7 05:48:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"A lot of states have information on the web for width restrictions and height will help with other states annuals for unfamiliar areas","replyToPid":0}
发表于 2021-2-7 15:35:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"you might have to go back old school the ol reliable map book its got a lot of info that will help you i do understand how this would have you wondering i had a little something like that happened to me when i became over the road driver those maps will show you things you need to know that the GPS dont good luck driver","replyToPid":0}
GMT+8, 2026-4-18 01:04 , Processed in 0.649194 second(s), 24 queries .
