查看: 318|回复: 7
Air dryer question
 楼主| 发表于 2021-2-3 08:14:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"The air dryer on my 08 Freightshaker pops off every 30/35 seconds which is seriously annoying to try and sleep with, and I'm sure its annoying to those around me which is why I try and park away from other trucks when possible!   There are no air leaks so I'm wondering what causes that and if there's a fix for it?   ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-2-3 10:51:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Like red muff mentioned,  you probably have an air leak.  Park away from any other running trucks, get up under there with a creeper and check the air system well for leaks before you buy any parts.","replyToPid":0}
发表于 2021-2-3 08:23:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Okey-dokey best solution that I could come up with check the alcohol. If it’s constantly turning on it’s detecting moisture. Take your gladhands off for some rubbing alcohol down in there. If that doesn’t work your purge valve is probably bad. Honestly there could be a number of issues with that. You could have an air leak and not be able to hear it get in there with some soapy water spray it down see if any bubbles come up. Best of luck","replyToPid":0}
回复 支持 2 反对 2
发表于 2021-2-3 10:31:30 来自手机 | 显示全部楼层
1063552 发表于 2021-02-03 00:23:06 Okey-dokey best solution that I could come up with check the alcohol. If it’s constantly turning on it’s detecting moisture. Take your gladhands off for some rubbing alcohol down in there. If that doesn’t work your purge valve is probably bad. Honestly there could be a number of issues with that. You could have an air leak and not be able to hear it get in there with some soapy water spray it down see if any bubbles come up. Best of luck
","text":"haha wtf is happening here 😵","replyToPid":415783}
发表于 2021-2-3 10:30:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Shut your truck off...problem solved. Then go change your purge valve.","replyToPid":0}
发表于 2021-2-5 22:45:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Start simple. Change the filter. Dryer filters are commonly overlooked in the PM process. If the filter looks like a goopy mess inside, it needs to be changed more often.","replyToPid":0}
发表于 2021-2-3 14:06:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the line from the air governor on the left side of the engine to the air dryer itself it's the skinny little line they got them push connectors on there if it leaks down and Pops off the purge valve take the fittings out and put compression fittings in their problem will more than likely be solved 25-cent fix","replyToPid":0}
发表于 2021-2-3 10:52:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"fix it","replyToPid":0}
发表于 2021-2-3 10:24:08 来自手机
","text":"wtf 😂👍","replyToPid":415783}
支持 1 反对 0
GMT+8, 2026-2-9 01:19 , Processed in 0.064688 second(s), 24 queries .
