查看: 201|回复: 4
Navigating
 楼主| 发表于 2021-1-30 00:17:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do you guys deviate and make adjustments on routing/directions while using this app?\nEven though the routing is perfectly fine for trucks, my company asks me to avoid specific streets etc. sometimes.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-1-30 15:47:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Who you calling a deviate","replyToPid":0}
发表于 2021-1-30 13:11:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can put in additional stops to route yourself differently, I do it regularly when I'm using a longer route avoiding poor road conditions.","replyToPid":0}
 楼主| 发表于 2021-1-31 00:59:03 来自手机 | 显示全部楼层
1032156 发表于 2021-01-30 05:11:28 you can put in additional stops to route yourself differently, I do it regularly when I'm using a longer route avoiding poor road conditions.
","text":"how do you add Highways/Byways as a Stop? \ndo you pick a nearby restaurant, business etc as a stop?","replyToPid":415512}
发表于 2021-2-4 10:16:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use a car Garmin, before that I used a paper atlas. I just apply common sense and situational awareness to everything I do. You will get yourself into bad situations, it's just part of trucking.","replyToPid":0}
GMT+8, 2026-4-16 10:14 , Processed in 0.107567 second(s), 24 queries .
