查看: 249|回复: 7
Does anyone use this gps on this trucker path ?? Any recommendations?
 楼主| 发表于 2021-1-29 09:12:17 来自手机 | 显示全部楼层 |阅读模式
发表于 2021-1-29 09:56:31 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I use it. It comes in handy because it helps you avoid toll roads and it displays low clearance areas, however it’s not perfect and the signs were it’s not complete. Also sometimes the address in regards to warehouses is on the opposite side of the street."}
发表于 2021-1-29 11:30:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use Smart Truck Route 2app, since 2018. most consistent than company gps, or ones bout from truckstops. its $60 a year though, very very customized to fit the drivers needs, with satelittle gps and being able to mark directions to the entrance and saving locations that dont popup on other gpses","replyToPid":0}
发表于 2021-1-31 13:49:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Truckers Path is the only GPS I use and with a little common sense, it's a fantastic app for navigation, plus let's you pre-plan your stops which means that I NEVER get caught without a place to park and end up on the shoulder of an off ramp!","replyToPid":0}
发表于 2021-1-29 21:54:46 来自手机
{"replyTo":"","text":"I don’t recommend anyone to use it. I did use it once in Chicago and it took me to No Truck Route. Less than a mile ahead I was pulled over by sheriff. Luckily he gave me a verbal warning & directions back to truck route. \nTo have a peace of mind on the roads, I recommend you to buy Rand McNally truck GPS. ","replyToPid":0}
支持 2 反对 0
发表于 2021-2-1 19:09:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just pay 9.99 a month and you will have all you need to work. By the way you have 7 day to try the application. The setting for 53” truck are already set so you will don’t have any problem to use the navigation system. Highly recommended!!!","replyToPid":0}
发表于 2021-2-1 18:58:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Best navigation system on the market. Never get lost. They are updating maps every month. For me best. Highly recommended!!! Good 👀 ","replyToPid":0}
发表于 2021-1-30 11:51:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"only use Google maps","replyToPid":0}
发表于 2021-1-31 01:41:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use google map and Garmin","replyToPid":0}
GMT+8, 2026-2-7 13:36 , Processed in 0.052372 second(s), 24 queries .
