查看: 391|回复: 12
Tips!!!
 楼主| 发表于 2021-1-24 02:22:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"Any recommendations for a first time lease driver? (We are team) 🧐","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-1-24 13:40:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Recommendations? RUN! FAR AND FAST!","replyToPid":0}
回复 支持 6 反对 0
发表于 2021-1-24 21:50:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why lease instead of own? ","replyToPid":0}
发表于 2021-1-24 02:45:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just remember, that truck owns you. You don’t own the truck. It’s a commitment 100% for however long your lease is. ","replyToPid":0}
发表于 2021-1-25 00:26:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't do a lease purchase, your just a glorified company driver!  there's several financing companies out there and many with work with you.  my cousin got financing with a 513 credit score auto repossession, he had to have 4k down on a 23k truck.","replyToPid":0}
发表于 2021-1-24 10:21:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"be sure you’re getting a good rate. As a lease driver you have to cover the lease, insurance, pre-pass, etc. it’s almost like being an owner operator. Because you are covering a lot of that you’re allowed to request a higher rate. Percentage of load is generally how it goes. If the lease is yours then I would say at least 80% or better that’s how it should be.","replyToPid":0}
发表于 2021-1-25 00:18:34 来自手机 | 显示全部楼层
612134 发表于 2021-01-24 05:40:44 Recommendations? RUN! FAR AND FAST!
","text":"TRUTH!","replyToPid":414677}
发表于 2021-1-24 07:19:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can find plenty of trucks in good shape for under 50k. Get your own financing at a credit union (banks charge too much) and the payments will add up to much much less than the fleece you’re considering. Companies go out of business everyday and if your name is not on the title, they won’t give you anything. There’s the rub, your names not on the title and you’ll pay a really high price (add up the payments and you be the judge) truckpaper.net I think has thousands of used trucks at decent prices ","replyToPid":0}
发表于 2021-1-24 21:37:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"lease with 100% owner/operators","replyToPid":0}
发表于 2021-1-24 03:43:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make sure you do a walk away lease!","replyToPid":0}
发表于 2021-1-24 03:01:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"talk to others leased on with that company..how have they been treated. Good Luck","replyToPid":0}
发表于 2021-1-24 06:02:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Right now with this market.... return it if you can. It will be nothing but frustration till at least July or August. You probably will be making same as if you’d work for someone for $.60 solo but with way much more headaches and responsibilities. I used to do lease but only for holiday season. Usually from mid October till end of January and would go back to company driver for $0.60. ","replyToPid":0}
GMT+8, 2026-3-22 05:40 , Processed in 0.108373 second(s), 25 queries .
