查看: 561|回复: 37
Bs election
 楼主| 发表于 2021-1-20 11:06:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"How long do you think it would take the Supreme Court to actually look at the election if we all shut down until they do?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-1-20 12:10:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not only did the Supreme Court look at it, so did countless other courts. I think it was something like 63 times that Trump tried to change the election results. The one that went to the Supreme Court was called the  \"big one\" from Texas but was quickly tossed out. You all can believe Trump's lies but there's a reason they don't hold up in court.","replyToPid":0}
回复 支持 4 反对 13
发表于 2021-1-20 13:56:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's over now let it go","replyToPid":0}
回复 支持 6 反对 5
发表于 2021-1-20 22:27:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep listening to FOX from your double wide. This was the safest election in history and THANKS GOD Trump is gone. Now we can get to work. ","replyToPid":0}
回复 支持 2 反对 8
发表于 2021-1-21 01:16:35 来自手机 | 显示全部楼层
789843 发表于 2021-01-20 16:38:54 Listen to yourself, \"Socialist Democrats.\" You're repeating everything you hear on Fox News or some other Right wing program. I hate to tell you this but those stimulus checks you received that Trump supported, are literally the definition of SOCIALISM! Does that make Trump a socialist?
","text":"Shut up you liberal left wing looney","replyToPid":414230}
回复 支持 6 反对 2
发表于 2021-1-20 20:30:01 来自手机 | 显示全部楼层
789843 发表于 2021-01-20 04:10:39 Not only did the Supreme Court look at it, so did countless other courts. I think it was something like 63 times that Trump tried to change the election results. The one that went to the Supreme Court was called the  \"big one\" from Texas but was quickly tossed out. You all can believe Trump's lies but there's a reason they don't hold up in court.
","text":"Trumps lies??? look at the socialist democrats.  we are about to see true corruption.  I will remind you","replyToPid":414167}
回复 支持 6 反对 2
发表于 2021-1-21 04:41:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Time to move forward with your life, loohzer. He lost, like a few hundred times over. Why can’t you folks believe anything that’s actually the truth? You blindly believe every lie told to you, but not a single truth. There’s a reason truckers aren’t known for their intelligence, this post is a good example. ","replyToPid":0}
回复 支持 1 反对 5
发表于 2021-1-21 04:44:54 来自手机 | 显示全部楼层
1024069 发表于 2021-01-20 20:41:14 Time to move forward with your life, loohzer. He lost, like a few hundred times over. Why can’t you folks believe anything that’s actually the truth? You blindly believe every lie told to you, but not a single truth. There’s a reason truckers aren’t known for their intelligence, this post is a good example.
","text":"Shove a taco in your mouth beener. Oh I forgot you like🥒","replyToPid":414280}
回复 支持 4 反对 1
发表于 2021-1-20 16:49:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trump needs to sue the Supreme Court","replyToPid":0}
回复 支持 3 反对 2
发表于 2021-1-21 04:52:42 来自手机 | 显示全部楼层
","text":"Old accusme! with more hatred","replyToPid":414280}
发表于 2021-1-21 04:45:38 来自手机 | 显示全部楼层
","text":"Stick to working parking lot . Something your good at","replyToPid":414280}
发表于 2021-1-20 11:57:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Forever","replyToPid":0}
发表于 2021-1-20 16:26:10 来自手机 | 显示全部楼层
","text":"the Texas one was not Trumps","replyToPid":414167}
回复 支持 2 反对 2
发表于 2021-1-21 00:21:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"It doesn't matter who ordered it. Trump urged his loyalists to help him and Ken Paxton took up that call. My point is they tried and they failed.","replyToPid":0}
回复 支持 1 反对 3
发表于 2021-1-21 00:36:58 来自手机 | 显示全部楼层
653958 发表于 2021-01-20 14:27:03 Keep listening to FOX from your double wide. This was the safest election in history and THANKS GOD Trump is gone. Now we can get to work.
","text":"Biden will lead the way beener","replyToPid":414215}
GMT+8, 2026-4-20 21:19 , Processed in 0.098020 second(s), 24 queries .
