查看: 301|回复: 12
eld/elogs
 楼主| 发表于 2021-1-20 03:19:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"what is a relatively reasonable price and good company you use for your elogs/eld","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-1-20 03:25:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use keep trucking, they definitely not bad ","replyToPid":0}
回复 支持 6 反对 0
发表于 2021-1-20 06:07:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use keeptruckin right now, fairly easy but bear in mind it also keeps track of your speed, I don't know if they all do or not but was told others didn't","replyToPid":0}
发表于 2021-1-20 04:16:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep Truckin is the best one","replyToPid":0}
发表于 2021-1-20 10:45:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"keeptrucking","replyToPid":0}
发表于 2021-1-21 11:07:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep trucking is really good and easy to use. Been using it for about 3 years now. ","replyToPid":0}
发表于 2021-1-20 10:16:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"KeepTruckin works great and is probably my favorite, easy to edit mistakes etc. Samsara isn’t bad either. If you want something on the cheaper side check BIT “Blue Ink Tech”","replyToPid":0}
发表于 2021-1-20 05:59:36 来自手机 | 显示全部楼层
766797 发表于 2021-01-19 21:43:27 and is FREE‼️❗‼️❗
","text":"👍","replyToPid":414139}
发表于 2021-1-20 07:00:13 来自手机 | 显示全部楼层
930998 发表于 2021-01-19 22:07:50 I use keeptruckin right now, fairly easy but bear in mind it also keeps track of your speed, I don't know if they all do or not but was told others didn't
","text":"I think my EZ-ELD tracks speed as well. It pings like every minute your location and speed. I noticed on the screen when a state trooper was inspecting my HOS inside the scale house once.","replyToPid":414141}
发表于 2021-1-20 09:47:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep truckin ","replyToPid":0}
发表于 2021-1-20 03:48:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Stoneridge EZ-ELD \n\n$150/annually \n\nPretty easy to use and edit if you ever need to. Company is in Michigan but the customer service people are in the UK. They are pretty timely on helping you out though.\n\n👌🏻 \n","replyToPid":0}
发表于 2021-1-20 09:45:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"track ensure is a good eld provider","replyToPid":0}
GMT+8, 2026-4-17 20:19 , Processed in 0.199880 second(s), 24 queries .
