查看: 261|回复: 9
App
 楼主| 发表于 2021-1-18 11:27:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"I would Like to know how reliable is this app?  GPS truck??  Im going to New Jersey and is well know for having low clearance bridges. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-1-19 02:28:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t listen to these fools I’ve been using the GPS along with my Garmin 8 Dezel and the GPS on here is  good for Trucks it has a few minor hiccups but it’s good has everything you need I still use it using it right now ","replyToPid":0}
发表于 2021-1-19 02:29:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Google isn’t a truck route GPS and using Google will get you into trouble ","replyToPid":413938}
发表于 2021-1-19 13:56:13 来自手机 | 显示全部楼层
669593 发表于 2021-01-18 18:29:09 Google isn’t a truck route GPS and using Google will get you into trouble
","text":"Ahaha my dude said google. That’ll get you in a heap load of trouble. ","replyToPid":413972}
发表于 2021-1-18 21:10:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"use google.","replyToPid":0}
发表于 2021-1-18 12:02:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t trust it. Use Hammer gps ","replyToPid":0}
发表于 2021-1-18 17:12:25 来自手机 | 显示全部楼层
758212 发表于 2021-01-18 04:02:17 Don’t trust it. Use Hammer gps
","text":"I'm from Jersey stay from up North.","replyToPid":413915}
 楼主| 发表于 2021-1-19 08:41:55 来自手机 | 显示全部楼层
669593 发表于 2021-01-18 18:28:06 Don’t listen to these fools I’ve been using the GPS along with my Garmin 8 Dezel and the GPS on here is  good for Trucks it has a few minor hiccups but it’s good has everything you need I still use it using it right now
","text":"thanks for the advice. good evening","replyToPid":413971}
 楼主| 发表于 2021-1-19 08:44:13 来自手机 | 显示全部楼层
","text":"i used hammer for 6 months and it got in serious troubles a couple of times.  but thanks for the comment.","replyToPid":413915}
发表于 2021-1-26 02:45:03 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Use an atlas 😂🤣😂"}
GMT+8, 2026-4-16 10:16 , Processed in 0.127380 second(s), 24 queries .
