查看: 252|回复: 7
Walmart’s DEF
 楼主| 发表于 2021-1-16 08:24:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"Guys, what do you think about this DEF? ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":812.0,\"name\":\"\",\"url\":\"\",\"width\":375.0}]","canComment":true,"externalShare":false}
发表于 2021-1-17 00:55:50 来自手机 | 显示全部楼层
868915 发表于 2021-01-16 16:02:21 My answer to def is a cat, witch I can pull 475 hp with 6.33 mpg.  Witch I can run at 75mph with 45 in the box
","text":"475 turn that kitty up","replyToPid":413761}
回复 支持 0 反对 8
发表于 2021-1-17 07:14:30 来自手机 | 显示全部楼层
868915 发表于 2021-01-16 20:56:10 Naaa at inframe time it is going all the way up to 550 at 1850, it is now 470 at 1650.  I ripped the 8 speed out and put a 18 speed and much happier and the mpg has improved
","text":"That's hp and torque will go good with that 18 speed","replyToPid":413791}
回复 支持 0 反对 8
发表于 2021-1-18 23:14:24 来自手机 | 显示全部楼层
发表于 2021-1-18 16:52:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"its all the same 5% cleaning ammonium nitrate 95% distilled water you can make your own for about 22bucks","replyToPid":0}
发表于 2021-1-17 00:02:21 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"My answer to def is a cat, witch I can pull 475 hp with 6.33 mpg.  Witch I can run at 75mph with 45 in the box"}
发表于 2021-1-17 04:56:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Naaa at inframe time it is going all the way up to 550 at 1850, it is now 470 at 1650.  I ripped the 8 speed out and put a 18 speed and much happier and the mpg has improved ","replyToPid":413768}
发表于 2021-1-17 01:30:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"get the def deleted have mechanic have the needle stuck at 1/4 tank and roll on","replyToPid":0}
GMT+8, 2026-2-5 03:49 , Processed in 0.093658 second(s), 24 queries .
