查看: 407|回复: 11
New OTR driver
 楼主| 发表于 2021-1-15 07:57:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"What do i do if i come up on a bridge that’s too low for my truck to go under? Do i stop and hold up traffic ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-1-15 09:29:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hammer on that mfer!!!!","replyToPid":0}
回复 支持 7 反对 1
发表于 2021-1-15 08:12:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a running start and sheer the top off, then charge your company for a new open top trailer. Should be worth a few bucks as it’s a custom build. ","replyToPid":0}
回复 支持 7 反对 1
发表于 2021-1-15 08:02:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"well yes , if it's not safe to turn around call the law to help you turn around. You might get a citation though.","replyToPid":0}
回复 支持 8 反对 0
发表于 2021-1-15 10:37:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"1 option - lower airbags on truck and (manually on trailer disconnect or bend the rod that keeps air bags level) learn how to do it before you have to. and drive very slow\n2 -  especially if it's 4 lanes, get in the opposing traffic lane and back up  \n3 - deflate tires if you have to","replyToPid":0}
回复 支持 3 反对 4
发表于 2021-1-15 11:27:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"you slam on the gas and scream yolo","replyToPid":0}
回复 支持 5 反对 1
发表于 2021-1-15 11:07:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes hold up and put hazards lights On ASAP. Check your options before going forward.\n\nBEFORE THAT HAPPENS INVEST IN TRUCK ROUTE GPS  \n\nI'm very happy with my Garmin Video recording gps DEZl Cam 785LMT-S","replyToPid":0}
 楼主| 发表于 2021-1-15 08:16:31 来自手机 | 显示全部楼层
643146 发表于 2021-01-15 00:12:47 Get a running start and sheer the top off, then charge your company for a new open top trailer. Should be worth a few bucks as it’s a custom build.
","text":"😂😂😂","replyToPid":413581}
发表于 2021-1-15 20:24:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hold my beer!","replyToPid":0}
发表于 2021-1-15 09:50:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes you do ","replyToPid":0}
发表于 2021-1-18 04:04:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"You should be able to avoid this situation 99% with using a truck navigation.\nWhatever, if you are facing this scenario, stop of course, u turn when possible or back up when possible to turn around by any chance. Make sure it’s safe and have a spotter helping you. \nWell always depends on the situation ","replyToPid":0}
GMT+8, 2026-2-7 13:36 , Processed in 0.069921 second(s), 24 queries .
