查看: 380|回复: 12
Navigation
 楼主| 发表于 2021-1-13 09:10:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey y’all. New here and just signed up for the free 7 day trial. Is the navigation on this app as reliable as the rand McNally truck gps?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-1-13 09:23:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin, Rand, and apps will All eventually put you against a low bridge or narrow no truck road. Rand atlas is the only thing where everything is properly audited. Company drivers don't even route themselves....","replyToPid":0}
 楼主| 发表于 2021-1-13 17:49:30 来自手机 | 显示全部楼层
1058657 发表于 2021-01-13 01:17:45 yes its the best I have a trucker path tattöö that's how great this app is.
","text":"That’s good. I’m a local driver, not getting out of my 150 air mile circle. And I’ve been driving since 2000. So I’ve seen most of the areas and roads I will be on. Just don’t want to put $300 or more into a truck GPS for no more than I’ll use it. Figure I can pay that $10 a month until I get used to the customers we have in our little area, and then cancel it. Thanks. ","replyToPid":413395}
发表于 2021-2-18 08:48:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"when I'm in the city's I use hammer that app has kept me out of some bad situations in California i use the latest updates it even tells what weight can be in what lane on California highways","replyToPid":0}
发表于 2021-2-18 08:52:52 来自手机 | 显示全部楼层
990702 发表于 2021-01-13 11:23:55 Spot on. Any of the GPS systems can lead a trucker into problems.  \nFor now, I  am a company driver.  Allow me to add, company makes a suggested route, and get a bit bent if you don't follow it.  I for one, and would recommend to any driver, buy a professonal grade commercial Altas. Check the suggested route and plan your best route.  if the company route is wrong, and many times it is.  call dispatch and have them change it. Explain why and any reasonable company will make the route adjustments.
","text":"that's why I use multiple GPS apps","replyToPid":413436}
发表于 2021-1-13 19:54:53 来自手机 | 显示全部楼层
","text":"“Explain why and any reasonable company will make the route adjustments.” \n\nYou obviously haven’t driven for PAM Transport 😂","replyToPid":413436}
 楼主| 发表于 2021-1-13 17:52:19 来自手机 | 显示全部楼层
956239 发表于 2021-01-13 01:23:37 Garmin, Rand, and apps will All eventually put you against a low bridge or narrow no truck road. Rand atlas is the only thing where everything is properly audited. Company drivers don't even route themselves....
","text":"Yep ","replyToPid":413396}
发表于 2021-1-13 19:23:55 来自手机 | 显示全部楼层
","text":"Spot on. Any of the GPS systems can lead a trucker into problems.  \nFor now, I  am a company driver.  Allow me to add, company makes a suggested route, and get a bit bent if you don't follow it.  I for one, and would recommend to any driver, buy a professonal grade commercial Altas. Check the suggested route and plan your best route.  if the company route is wrong, and many times it is.  call dispatch and have them change it. Explain why and any reasonable company will make the route adjustments.","replyToPid":413396}
发表于 2021-1-14 02:35:25 来自手机 | 显示全部楼层
478405 发表于 2021-01-13 09:49:30 That’s good. I’m a local driver, not getting out of my 150 air mile circle. And I’ve been driving since 2000. So I’ve seen most of the areas and roads I will be on. Just don’t want to put $300 or more into a truck GPS for no more than I’ll use it. Figure I can pay that $10 a month until I get used to the customers we have in our little area, and then cancel it. Thanks.
","text":"Sounds like a plan👍","replyToPid":413432}
发表于 2021-1-15 15:45:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"In my experience rand McNally is not as good as Trucker's Path in the big cities but is better in rural areas.  Trucker's Path struggles in small towns and can sometimes not tell where you are when you have low bars.  Also, Garmin is more reliable for navigation but you need good internet to update their GPS maps.","replyToPid":0}
发表于 2021-1-15 18:43:38 来自手机 | 显示全部楼层
677453 发表于 2021-01-13 11:54:53 “Explain why and any reasonable company will make the route adjustments.” \n\nYou obviously haven’t driven for PAM Transport 😂
","text":"Key word being 'Reasonable' company.  After hearing  'Your the driver...' whenever calling in any problems.  That became a modified goto statement when disputing routes too.  \n'I'm the driver. There is a total of 108 miles of road construction with a projected four hour  delay on the suggested route. \n If we move to this new route I just emailed to you, it is only 62 miles longer but we get there three hours sooner, and it's more safe.'\n'Reasonable' right?","replyToPid":413438}
 楼主| 发表于 2021-1-16 06:28:56 来自手机 | 显示全部楼层
","text":"I started driving tractor trailers in 2000. Know all about the atlases. They are good to get point a to point b. But no atlas can get you from the interstate to the customer. And I remember all too well, having to call customers for directions. Sometimes they are right, and sometimes wrong. And I remember driving through cities at 2am at 5mph with a flashlight out the window, to try and see road signs so I wouldn’t miss a turn, and building numbers, so I wouldn’t miss the entrance. Thanks, but no thanks. LOL. I’ll always carry my atlas in case I get in a bind and the gps is out. But I’ll use the gps lol. ","replyToPid":413436}
GMT+8, 2026-2-4 04:41 , Processed in 0.103453 second(s), 24 queries .
