查看: 67|回复: 0
Leaking Radiator on 04 Freightliner Columbia Detroit 14L
 楼主| 发表于 2019-1-28 16:54:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Okay guys so I'm having a weird issue with my tractor. A few weeks ago I started noticing a tiny trickle of coolant leaking from a plastic cover under my radiator. I have notice that when my temp on my water goes to 200 it begins to leak and anything under it doesn't leak at all. Now the small trickle is a few drops and makes a puddle. Can this be a bad thermostat or a bad radiator? I'm currenlty putting in a gallon of coolant a day now. Need help!!","pics":"[]","canComment":true}
GMT+8, 2026-2-4 12:26 , Processed in 0.050785 second(s), 23 queries .
